Will those wheels fit? START HERE.
#2719
Well, can't find the exact answers to my question, just that at minimum I need to pull the fenders, but here's the wheel sizes:
19x9 +22
19x10.5 +32
I am dropped with s-tech's, and currently have 225/40/19 and 255/35/19 Invo's.
What will be necessary to get these rims to fit without issues? I'm hoping just rolling the fenders, but I got a feeling new tires will be part of the equation, which sucks because I JUST bought this set of Nitto's.
Thanks guys!
19x9 +22
19x10.5 +32
Thanks guys!
#2720
19x9 +22
19x10.5 +32
Thanks guys!
19x9 +22
19x10.5 +32
Thanks guys!
just kidding.
a pull-roll (natural action of fender rolling will slightly pull the fender outward) should be fine.
tires: in the front, you might be able to get away with 225/40-19, though you should've gone w/ 35-series up front. in the rear, you might be able to get away with 255/35-19 on a 10.5.
the fender bolts in the front will have to go, and you'll have to find a way to secure the bumper tab to the fender tab. you can keep the rear fender bolts in, but it would be a good idea to shave the rear tabs down to a minimum.
hope this helps.
#2721
[QUOTE=projectdna;6773791]265/30-20
Originally Posted by FreshIS250
I am trying to find out what tire size in the rear I can run... rear wheels are 20x10 with a ET45... I'm guessing this is the offset
2007 is250 lowered on road magnet springs with a 2inch drop all around
265/30-20
i went with a 275/30-20 in the rear.. will i need to make any fender adjustments on this? I'm hoping I won't have to... kind of anxious to throw these wills on asap...
265/30-20
#2722
and since you already went with those tires on those wheels, you'll just have to mount up the wheels and tires, and find out for yourself.
best of luck.
#2723
he asked me in PM also, i said it should fit, but... he never mentioned his fenders were un modded. a 275 without rolled or shaved fenders is gunna be tight.
just so everyone knows, I ASSUME that if you dont say anything about no fenders mods, you either have them done already or ARE NOT AGAINST modifying your fenders...
to everyone![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
YOU NEED MODDED FENDERS FOR AGGRESSIVE WHEELS PERIOD
to everyone
#2724
i demand to see what wheels you are thinking of getting before i give you any advice...
just kidding.![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
hope this helps.
just kidding.
hope this helps.
I wanted a 35 series up front but in order to get all Invo's I could only get a 40 series since I had no time before leaving Texas for the Pursuit. It already rubs something when making semi-tight turns.
If you browse the classifieds, shouldn't be hard to find which rims I'm after...
#2725
I just traded in my G35 for a 2007 IS250 RWD and was wondering if my wheels would fit. I have Vossen CV1's with 275/30/20r and 245/30/20f. The wheels are 20x10.5(+25) and 20x9(+20). I currently have the stock suspension because I just got the car this week. Will these fit without any mods?
#2726
Thanks man! I actually meant to write roll not pull in my post, so I'm glad that should be the extent of the fender work besides ridding of tabs and such.
and I have a full Wald kit on the way, so these more aggressive wheels are very necessary ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
#2727
I can tell you I was rubbing like crazy with 225/40/19 on the front of mine and I was running a 19x8.5 +28 on stock suspension. I removed my 15mm spacer to make it a +43 and I was still rubbing bad. I would not run the 40 series tire on the front. It is almost 2 inches taller than the stock tire.
#2729
Is there a catalog of all Lexus wheels from all models that will fit a 1998 GS 400 with no issues?
e.g. 2008 OEM Lexus GS 17's
or ES350 wheels
etc
Wheels that I cannot easily see, but can be shipped to me.. thanks
or ES350 wheels
etc
#2730
on a related note, the invo's are okay at best from personal experience...
Thanks for the personal experience
I'm budgeting to buy new front tires if I get the wheels, just so I'm not shocked if after the roll and cutting tabs it still rubs with the tires I have. Is a 225/35 a good/best option after rolling the front fenders or do I need a more stretched tire
