Will those wheels fit? START HERE.
Old 11-15-11, 12:01 PM
  #2776
projectdna
projectdna's Avatar
Originally Posted by Fuzzie
i have the stock 18s on my is250 with 15mm spacers up front and 20mm in the rear.
i like how they look but im scared of running on spacers.
my tires are tucked and is as flush as it can get without touching the fender. i love my drop and dont want to raise the car.
can someone recommend me wheel width and offsets that will be as close to my current setup?
im running 225/40/18 and 255/40/18 tires
i kina want the wheels to go pass the fenders just a little but dunno if my tires will stretch
18x9/18x10 +30.
Old 11-15-11, 02:28 PM
  #2777
Fuzzie
Fuzzie's Avatar
will 9.5 and 10.5 make a big difference? thats what a vendor on here recommended
Old 11-15-11, 03:14 PM
  #2778
MyIS350G
MyIS350G's Avatar
Originally Posted by projectdna
actually, you just posted up tire sizes and implied "pick one" - which is exactly what i did.
now, if that answer didn't work for you, try asking a question that will get you an explicit answer.
technically, i implied it.
thank you.
I guess wasnt clear on that when i said
"Wheels specs:
20x8.5 +15
20x10 + 20
"will" 225/35/20 and 245/35/20 fit?
Or do I have to go with 225/30/20 and 245/30/20?
All fenders rolled and on coils. "
but thanks.
I just got an email and they said its gonna be 20x8.5 +20 and 20x10 +20.
Old 11-15-11, 06:00 PM
  #2779
Brian@Vossen
Former Sponsor
Brian@Vossen's Avatar
Remember any questions on Vossen Wheel fitment you can also contact us here! Thanks.
info@vossenwheels.com
This thread rocks!
Old 11-16-11, 06:22 PM
  #2780
steezy
steezy's Avatar
Anyone stretched a 215/40 on a 9.5? or a 235/40 on a 10.5?
Old 11-16-11, 07:08 PM
  #2781
MyIS350G
MyIS350G's Avatar
found this might help some of you guys:
http://www.1010tires.com/WheelOffsetCalculator.asp
Old 11-16-11, 09:30 PM
  #2782
projectdna
projectdna's Avatar
i think Mv350 has.
great source. admittedly i used to use it - until i figured out the calcs.
though, there are a few limitations with that wheel offset calculator, some more obvious than others:
- it gives you values relative to your current wheel set-up vs. values from an absolute fixed point of reference (i.e. the pad where your wheels bolt up to)
- it does not tell you whether the proposed wheel width will clear the fenders
- and of course, tire size is not factored in
but for someone new to the wheel game and looking to crunch some numbers for offsets, that's a great starting point.
Old 11-16-11, 10:14 PM
  #2783
MyIS350G
MyIS350G's Avatar
^^Yes, ive learn a lot using google for some real experience.. looking to see if any other 2IS owners running 225/35/20 and 245/35/20 on 20x8.5 et20 and 20x10 et20 wheels. so far only found one person (not +20 but +22)but he doesnt say anything about pulling fenders or not.. his name is MrMark and he hasnt been active since 2008 or 2010 cant remember.
Old 11-16-11, 10:25 PM
  #2784
projectdna
projectdna's Avatar
this has been discussed before, but since you're intent on those sizes i recommend that you punch in your proposed tire sizes and our recommended tire sizes in 1010tire's tire size calculator (again, i used it up until i figured out the calcs myself) and see if what we're suggesting makes sense or not.
Mv350 and i aren't trying to give you a hard time, but we don't know how else to tell you that, while the widths are fine, go with the lower aspect ratio.
Old 11-16-11, 10:31 PM
  #2785
MyIS350G
MyIS350G's Avatar
^yea i know what you guys recommended thing is I got a set of tires( 235/35/20, 245/35/20) laying around, I was thinking about selling them and get the 30s but have no patient to wait plus im running on some bald oem wheels with 18s right now.
Old 11-17-11, 08:02 AM
  #2786
A.C Milan
A.C Milan's Avatar
Hi,
Its been a long time , I've bought a set of 19" and I'm worried about tires , I'm not that into tire and wheel fitments so I really need your help guys.
These are the measurements:
Size : 19 x 8.5 (F) & 19 x 9.5 (R)
Offset : 38mm (F) & 45mm (R)
Now , I will be running on stock height , so how far can I go with the tires.
Roads here are rubbish so I'm hoping I can run a 40 or even 45 series tire ? Or Am i too optimistic .
Also I would like to ask , Can i run non-staggered tires on these staggered wheels? Lets say 235 all around ?
I'm on stock 17" btw.
Thanks
Old 11-17-11, 09:14 AM
  #2787
projectdna
projectdna's Avatar
Originally Posted by A.C Milan
Hi,
Thanks
too optimistic. try 35-series (40-series would be too tall; 45-series is even taller).
you can run non-staggered tires on your proposed wheel specs, but 235 is a visible "stretch" on a 9.5"-wide wheel. and if your roads are "rubbish", i wouldn't recommend it.
if you're set on running 235's on 19" wheels, here's the skinny: 235/35-19 + 19x8.5" +38 (f/r).
Old 11-17-11, 10:15 AM
  #2788
Mv350
Mv350's Avatar
hey steezy i havent done a 215/40 on a 9.5 but i have done a 225/40 on a 10.5 and a 10 they stretched perfectly fine. ive also done a 225/35 on a 10.
and for the pix
225/40 18x10 the rear is 265/35 on a 12
225/40 18x10.5
225/35 18x10
i imagine a 215/40 on a 9.5 will be no problem.
and a 235/40 on a 10.5 no problem cause ive done it with a 225/40.
Old 11-17-11, 10:35 AM
  #2789
steezy
steezy's Avatar
cool much help MV350, now gotta decide what brand
Old 11-17-11, 02:05 PM
  #2790
Mv350
Mv350's Avatar
my yokohama s drives were by far my favorite stretch. run really well.
Quick Reply: Will those wheels fit? START HERE.
