Will those wheels fit? START HERE.
#2852
guys I am in the market for coils but would hate to end up buying something with wrong spring rates....
The most aggresive I ever plan to go on the rear is 10.5+25, would megan ez streets with a spring rate of 10kg/mm and 8kg/mm be stiff enough to hold those offsets?
thanks
thanks
#2855
What would be a better setup (no rubbing, etc) , considering I'll be dropping on H&R?
19x8.5 32 / 235 35 19 front
19x10 38 / 265 30 19 rear
or
19x10 38 / 275 30 19 rear
I've already gathered some suggestions from a few member, but any additional suggestion would be great! Thanks so much for your help!
or
#2856
or
I've already gathered some suggestions from a few member, but any additional suggestion would be great! Thanks so much for your help!![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
or
unless you're offering significantly different wheel/tire specs, there isn't much to discuss between 265/30-19 and 275/30-19.
#2859
Will these fit my isx50
19” - 10 1/2J - Pressed Graphite - 5H x 114.3 - +22
19” - 9 1/2J - Pressed Graphite - 5H x 114.3 - +22
any fender mods necessary any one have them?
tires will be 235 35 19
265 35 19
http://www.youtube.com/watch?v=JSFEc...eature=related
265 35 19
#2860
with fender modifications (roll-pull + shaving down the fender tabs) and careful selection of tire sizes, yes, those TE37 SL's will fit.
235/35-19 should be fine up front. datplayaz runs 265/30-19 on a 10.5" +22 on his TE's, and from a visual check it looks like it clears the fenders.
with those widths and offsets, you have to modify your fenders. no exceptions.
#2861
#2864
Im looking for a set of 19s for my IS250 , im looking at 19x9.5 front and 19x10.5 rear with a +30 offset on both wheels , is this offset ok with such a wide wheel?
Thank you.
Thank you.
#2865
I'm about to order a set of wheels but is wondering if the following spec would work..
19x8.5 +23
19x10 +29
My shop suggests to go with below to be safer
19x9 +31
19x10 +32
Im willing to stretch and roll fender, def. no pull, and i have coils to adjust height.
Will the first specs work? Thanks in advance.
19x8.5 +23
19x10 +29
19x9 +31
19x10 +32
