Will those wheels fit? START HERE.
#2987
I am running the 19" F-Sport wheels 19x8x40 and 19x9x40. I don't know much about the offsets and the like but that is what the install instructions state.
Recommended and currently on the car is 225/35/19 and 255/35/19. The guy at the tire store (Butler in Atlanta) suggested I move to the 235/35/19 up front.
Will that cause any clearance issues?
Will I need to change the rear size as well?
He stated that the 225 was a "small" tire and the 235 would be better.
#2988
For an 8" wide wheel, 235 is the square fitting tire.
Technically the tire is wider and will be closer to the fender (although a very negligible amount) but it shouldn't give you problems.
Honestly I wouldn't even bother opting with the 235s.
#2989
has anyone done a 19x9.5 all around on the gs with a 35 offset. newbie here
I know people get tired of hearing the same questions but i just need a fast quick response. Im purchasing 19 inch bbs lm replica in a couple days but Im not a great fan of staggered . Would like to know if 9.5 in the front would give me an issue as for fender problems or fitment of anykind . Spacers ??? Going to drop it on eibach springs ... Best choices +35 or 30. Need ur guys opinion thanks
#2990
/rant
but here's your fast response.
yes on fender work, and call varrstoen for brake caliper clearance.
/fastresponse
and my opinion?
if you want to spend some "ima boss" money, buy some real, authentic wheels instead of cheapin' out and buying some knock-offs. if you don't want to do the fender work and/or run thinner-than-oem-spec tires, don't look at high-width/low-offset wheels. and if you can't do either, stay stock. do it right once, or don't do it at all.
/rantx2
#2992
Anybody know if my stock tires *Back Tire* ( Bridgestone, 255/40R18 95Y ) * Front Tire* ( 225/40R18 88Y ) on my stock 18x8.5 wheels will be able to stretch to fit a wheel with 18x10.5 ??
#2993
Wheel fitment help !! Please !
Whats up guys I am about to order a set of BC Racing forged WA03 wheels and I am a total nub at wheel fitment. I have been researching the " will thies fit " thread for about two weeks and I am almost more confused than I started. I was thinking 19x8.5+30front 19x10+38 rear , I have a Lexus IS250c and*I want to be 100% sure before I order them, I want the wheels as flush as possible without having to roll the fenders but am willing to if absolutely necessary ( i will be lowering the car on coils later ). Any advice would be greatly appreciated. Thanks for your time ( and please don't just tell me to got read the fitment threads because I have read through over 150 pages)
#2995
#2996
19x8.5 +30 is perfect. Flush and no fender mods needed - its what Im running. If you go more aggressive I guarantee you it WILL rub.
For the rear you can go with whatever is equivalent to 19x9.5 +35... you might need to mod fenders on that one but I'm not sure... (Im running 19.9.5 +35... and there is a few mm more left.... but again I'm not sure if it will require any mods)
#2997
- - G T V I P - -
#3000
I know my wheels will fit. My question was lugnuts. I was wondering if you guys could help me out real quick. I just bought some concept one rs-8s they are 19s.
8.5 +38
10.5 +45
^ not sure if that matters and was seeing if these would fit. (i have a 2006 awd)
I was wondering if these would fit before i buy them. Thanks
http://www.ebay.com/itm/400269468113...#ht_5996wt_949
8.5 +38
10.5 +45
