Will those wheels fit? START HERE.
#3078
maybe. you'll definitely have to roll and pull the fenders - and not just a light pull, but a considerable pull.
you'll also have to run stretched sizes like steezy mentioned.
the +12 varrstoens are not made for the 2is. spending all that work to get a set of replica wheels onto a car and have it barely drivable... not worthwhile for a cool parking lot stance.
#3081
You can get camber kit. But there goes your tires. I only shaved my rear and i clear 10.5 +10 with the megan camber arms. I suggest you get +22 all around.
#3084
I apologize for my ignorance; I never have dabbled in wheel filament prior to now. I am having a local shop measure the caliper clearance and I will tell them to go with the listed offsets you mentioned for these wheels: http://www.lomaforged.com/alloy%20cu...heel%20rsr.htm
What tires would be best to order running with H&R Springs with this type of setup? (front = 19x8.5 +34, rear = 19x10+42)
Any fendor mods other then the heat gun?
Thank you again for your guidance!
rarely does offset dictate caliper clearance, although lower-offset wheels have more caliper clearance than its higher-offset counterpart.
but if given that those wheels will have caliper clearance with high (<40) and low (< 20) offsets, quickest and easiest way is to copy forgestar's specs for the 2is.
front = 19x8.5 +34, rear = 19x10+42. here's how it'll look:
https://www.clublexus.com/forums/whe...-f14-mint.html
#3086
rear: 265/30-19 as-is, or alternatively, 275/30-19 + rolled rear fenders.
#3088
almost time to buy some near rear tires so im here to ask the experts my current rear is 19x10 +37 on 265/30 but i feel like the 30 series is too small i wanted to know which tire would work best and i dont want a ton of stretch 245 / 35 or a 255/35 ?? thanks in advance....
