Will those wheels fit? START HERE.
#3107
Dammit I'm so confused lol. LAST 3 questions, I swear:
1) Idk whether to roll my fenders or not. When I go to sell my car and throw my stock wheels back on, won't the roll be noticeable?
Then, if i do roll my fenders:
2) I want +22 offset for sure. However, I do not know whether to go with 8.5F and 9.5R or 9.5F and 10.5R. What is the SAFEST, most economical (tire wear wise), and easiest to find tires for?
3) Then, after selecting the wheels widths, what are the SAFEST and most economical (tire-wear wise) tires sizes I can run on those wheels?
all that permanent work for a set of varrstoens? i question how worthwhile that will be.
#3110
Dang, if it's THAT noticeable, I guess I'll just settle for +32
No fender work required then, right?
And no one answered my 2 other questions:
1) I do not know whether to go with 8.5F and 9.5R or 9.5F and 10.5R. What is the SAFEST, most economical (tire wear wise), and easiest to find tires for?
2) Then, after selecting the wheels widths, what are the SAFEST and most economical (tire-wear wise) tires sizes I can run on those wheels?
Thanks for the help!
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
since you're avoiding fender modifications and going with +32 offsets, here's what your set-up should look like:
19x8.5/9.5 +32
225/35-19 + 255/35-19
you may have to heat the fender lining out of the way, but it's a small detail compared to full-on fender modifications.
#3111
Would this rim fit my 2009 is250 awd
The specs of the rims are
Front and Rear
Offset: 42mm
Backspacing: 6.49"
Bolt Pattern: 5-114
Rec. Tire Size: 225/35-19
Weight: 28.0lbs.
Does the is250 and is350 have the same bore diameter?
Front and Rear
Offset: 42mm
Backspacing: 6.49"
Bolt Pattern: 5-114
Weight: 28.0lbs.
#3112
two expectations when getting wheel/tire recommendations from tire rack:
1. whatever they recommend will fit (or at least highly likely fit)
2. whatever they recommend will be an ultra-conservative recommendation that require no fender modifications.
with that out of the way...
the is250 and is350 have the same hub bore size (60.1 mm or 60.06 mm, depending on who you ask).
#3113
Hey projectdna,
Thanks for answering a few of my questions. Hopefully this will be the last if this guy can sell them to me.
Front 20x8.5 Front (2 wheels) Semi Concave +40 Offset
Rear 20x10.5 Rear (2 wheels) Deep Concave +46 Offset
Found someone that is selling forgestars f14s.
Can I get your opinion on this fit? What kind of tires would I need to run?
Would it clear the front brakes and any issues with running this size?
I am now lowered on S techs and factory shocks. I want to try to avoid doing any fender mods but if I have to then I will.
#3115
Hey projectdna,
265/30-20 in the rear. not sure if you can do 275/30-20.
#3116
Hey projectdna,
Those tire sizes are HUGE for the front. I dont recommend them.
If you keep them and go 2" drop you will need to atleast relocate the tabs. dna will be more help here.
#3117
downside is, 255/35-18 on a 9"-wide wheel will have very upright sidewalls.
for the front, those wheel widths and offsets sit the wheels relatively closer to the fender edge - 20 millimeters closer, to be exact. combine that with upright sidewalls, and you may have clearance issues - moreso if you're lowered.
my recommendation? ditch the 255/35-18's for 225/40-18's up front.
btw, are you running this on an AWD 2is? if not, why run a square set-up?
#3118
Refer to dna's post for recommended tire sizes, I see you ask brake clearance, do you drive a 250 or 350 ?
Thanks for yalls help...
I drive a IS350.
#3119
upside is, 255/35-18 has the same sidewall height/rolling diameter as 225/40-18.
yeah,its for awd 2is.whats a squre set up?im a newbie on this.thanks.
#3120
staggered set-up = front wheels/tires are not the same size/specs than the rear wheel/tires
i recommend going w/ 235/40-18's on 18x9's. the sidewalls are a little bit taller but won't be as upright on a 9"-wide wheel, and they're wider than 225's.
