Will those wheels fit? START HERE.
Old 04-15-08, 02:09 PM
  #316
passnu2
passnu2's Avatar
Originally Posted by JDub23
Thanks for the info. I'll post pics for sure once I get them or whatever else I decide on.
unless you want the "strech' look then go with 275/30 You will be just fine!
If you want to get agressive you can go 275/35 like i did and roll your rear fenders!
Good luck. Search my post and see my wheel set up in the aftermarket thread..page 103?? or something like that.
Old 04-15-08, 03:10 PM
  #317
ChrISF
ChrISF's Avatar
stretch FTMFW!
Old 04-15-08, 05:57 PM
  #318
Signal_jp
Signal_jp's Avatar
Originally Posted by EyeEstwo50
stretch FTMFW!
hell yess!!
Old 05-27-08, 01:18 PM
  #319
D.Jobin
D.Jobin's Avatar
Default Any possiblity of making these wheels work?
Ive had these 2 week old custom 20" Asanti's sitting in my garage for the past month. Theres two problems though:
1. They fit a BMW 5 series (5x120 bolt pattern)
2. Two of them are bent (hence why they're sitting in my garage)
Now I'm sure it would be a small fortune to get them repaired, but I'm sure it would be cheaper then the $8000 price tag they came with. My biggest question is ofcourse if anyone makes lug adapters that I could use to achieve that 5x120 bolt pattern, or if it would even be worth pursuing? I'd hate to see these beauties go to waste!
Old 05-27-08, 02:32 PM
  #320
passnu2
passnu2's Avatar
That Lip is so HOT...
here is a place that should make them custom for you. the question is going to be with them on and the offset of those rims will they fit? BMW has some pretty aggressive offsets.
http://www.skulte.com/index.php/cPath/21
G/L
Mike
Old 05-27-08, 03:50 PM
  #321
D.Jobin
D.Jobin's Avatar
Ok so I tried to decode the serial numbers on the back of the wheels and this is what I got.
AF144205120ET25RF and AF144205120ET20RE
So I'm assuming the offsets for the front wheels are +25 and the rear wheels are +20? The "ET" means offset right?
If they are in fact +25 and +20, any chance in making this work? I have no clue about offsets or anything like that. WHEEL EXPERTS I NEED YOUR HELP!!!
Old 05-27-08, 03:55 PM
  #322
DailyDrive
DailyDrive's Avatar
what's the width of these wheels? that would help also. they are a beauty
Old 05-27-08, 04:08 PM
  #323
D.Jobin
D.Jobin's Avatar
Ehh I'll hafta get back to you on that. The tires that are on there now are 245/35 and 285/30 if that helps any. If I had to guess I would say 20x8.5 and 20x10.
Old 06-03-08, 12:56 PM
  #324
AK-47
AK-47's Avatar
Default offset fit ok?
Hi, would the following setup ok for IS350?
18x8.5 +30 all around.
Old 06-03-08, 01:37 PM
  #325
llamaboiz
llamaboiz's Avatar
to answer your question, yes, even with a drop thats a mild offset for 8.5" rims and you'll have no problems running the 'big tire' look that you guys on da mainland like so much.
BUT~
why not staggard rims?
Old 06-03-08, 03:33 PM
  #326
passnu2
passnu2's Avatar
don't be jealous
I agree with llamaboiz that you are fine with the rim width and offset. why not a wider rim in the rear? 19 x 8.5 +35 front and 19 x 10 +38 would look sick and work! Nice and flush with out having to stretch the tires like the cool guys *cough* i mean llamaboiz likes it
You have options here and many to help you out
Good luck on your search!
Old 06-04-08, 12:57 AM
  #327
AK-47
AK-47's Avatar
I'm looking for some use Volk TE's, is just that I saw some on ebay, with that setup. don't want to spend too much on wheels. thats y can't get perfect fittment.
Old 06-10-08, 04:14 PM
  #328
JOROB
JOROB's Avatar
Default Wheel fitment question?
Alright my 350 is lowerd on s-techs and i would like to know to if a 225/35/20 and a 275/30/20 would fit ok on my car? I am looking at getting a set of sevas s55 in a 20 by 8.5 and 20 by 10. Will i rub? 40 offset.
Old 06-10-08, 04:51 PM
  #329
Signal_jp
Signal_jp's Avatar
i doubt you will rub with a +40 offset. your fronts are fine, you can even go 235/35 but if your worried about the rear, go with a 265/30 or even a 265/35
Old 08-07-08, 12:15 AM
  #330
nahhmeen
nahhmeen's Avatar
Default offset question
would this setup work on an IS250??
19x8.5 +28 19x9 +38
Quick Reply: Will those wheels fit? START HERE.
