Will those wheels fit? START HERE.
#3452
Hi folks, planning on my next rims for the IS, gonna be a daily 18" setup. 18x9 in the front and 18x10 in the back. I wanna run my stock tires, F 225 / R 255. My fenders are rolled alredy, no pull though.
The wheels I want are both available in offsets of 20 and 35. Wich offsets should I chose for my project??
Thanks
Thanks
#3454
Thanks
Thanks
backspacing for 11" +35 is ~0.7" more than the backspacing for oem's (8.5" +50).
#3455
Hey guys, moving to a new setup this year. A buddy is selling some wheels with the following spec's
Front - 20x9.5 +41 on an R-Disk
Rear - 20x10.5 +47 on an R-Disk.
From my own maths, it should fit with 225's and 245's on the front and rear respectively. I'm on the standard Linea Corse fitment (19x8.5 +28, 19x10 +42) on coils and I'm almost rub free. Can anyone check if that'll work?
#3457
yes.
#3458
I was looking at a set of wheels but they are very wide. I was wondering if someone can tell me if it will fit.
Its 20x10.5 +50 front and rear
225/30 and 255/30
Will it fit?
[edit]
I know nothing about offset and stuff but I was told that I might need spacers so that it wont hit my suspension? Sounds like a lot of trouble. Also If it help or not, my car isnt lowered and I dont plan on lowering it for a while.
225/30 and 255/30
Will it fit?
[edit]
#3459
i am on OEM 17" wheels but i don't know the specs. 225/45 tires..
the car is lowered to a no finger gap pic
and it rubs in the front. whats wrong? is the ride not stiff enough? i know i need to heat the fenderliner.. and i think i am hitting the bumber tab.. tho it is not really bad there are some minor marks of rubbing on the fenderliner.
#3460
Hello,
19x8 +35 front and rear
225/40
15mm spacer in the front
Stock suspension
Since the fronts are rubbing, I am wondering if I can put 225/35 on them and it'll stop? I might go 10mm spacer instead too.
225/40
Stock suspension
#3462
225/30 and 255/30
Will it fit?
[edit]
225/30 and 255/30
Will it fit?
[edit]
and given the ultra-conservative offset, you may have suspension clearance issues.
and no, you're not going to solve your problems going from a 15mm spacer to a 10mm spacer. unless you have clearance issues, run without the spacers altogether.
19 x 9.5/10.5 +12 is 10mm more aggressive than 19 x 9.5/10.5 +22. as such, you'll need to do that much more work.
and check your regional sections for fender modification specialists.
#3464
Hi guys,
I wanna get some rims either 19x8.5 (front) 19x9.5 (rear) or 20x8.5 (front) 20x9.5 (rear) but don't know anything bout offsets. Is there a web site you can go where you enter in your rim size and it suggest a offset for you?
I'm trying to go with a conservative flush also, looking not to aggressive, something decent that's nice and clean. This is my daily driver car so I also would like to try to avoid any fender modifications but if i had to i would.
My drop will be on BCR coilovers with a 1 finger gap all around.
Can you guys help me on the offset and the tire size? Much appreciated
#3465
Hi guys,
I have a '06 IS350 and want to add new rims but don't know a lot about offsets. I was thinking of getting 19x8.5 fronts and 19x9.5 rears with 35mm and 45mm offsets respectively. Would I need any spacers or make any mods? Also, what would be good tire pairings? Would 235/35 in front and 265/30 in rear be a good setup? BTW - my suspension is stock.
Thanks in advance.
Thanks in advance.
