Will those wheels fit? START HERE.
#3511
Sorry projectdna~ I forgot to mention works brombacher wheel offers 5 x 114.3 now. I contacted Workwheel USA and confirmed the chart I linked has same offset as 5 x 114.3 bolt pattern.
Please help me out projectdna~ Also should I get 225/35/19 and 245/35/19 tire size? Thanks alot
#3512
1st choice:
F: 19 x 9.5 + 40 with 60mm lip size or +27mm with 72mm lip size (L disk)
R: 19 x 10.5 + 27 with 85mm lip size or 15 with 98mm lip size (L disk)
2nd choice:
F: 19 x 9 + 34 with 60mm lip size or +21with 72mm lip size (L disk)
R: 19 x 10 + 21 with 85mm lip size or +8 with 98mm lip size (L disk)
2nd choice:
#3513
Do Konig Hotswap wheels fit on a rwd IS250, 2009, with the 18" wheel option?
http://www.tiredealersites.com/konig...ails&wid=12098
I'm in love with these, Konig's website seems to list them when I search for everything and input all my vehicle info, ammy doesn't think they will fit... tried searching the forums, didn't find any information on these...
seems they almost don't fit, but they did pop up under their search for my vehicle...
#3514
-url snip-
-url snip-
just because they should bolt up and might clear the brake calipers doesn't mean you should consider them.
#3515
Hey,
I am wondering if these will fit? I am pretty new to the whole offset business and I am wondering what kind of fender modifications will I need? This would be on my daily driver.
I am trying to get the VMR V710 rims here : http://www.velocitymotoring.com/wheels_v710.html
F: 19x8.5 +35
R: 19x9.5 +22
I understand that I will need to get hubcentric rings to fit the 73.1 to our 60.1.
Does anyone know any other rims that look like these, since it sounds like the IS requires higher offsets?
F: 19x8.5 +35
R: 19x9.5 +22
#3516
#3518
Hey,
I am trying to get the VMR V710 rims here : -url snip-
F: 19x8.5 +35
R: 19x9.5 +22
F: 19x8.5 +35
R: 19x9.5 +22
typically on lowered 2is's, you should be able to get away w/ no fender mods in the front, but you will need fender mods in the rear (rolled fenders). also consider shaving the fender tabs.
try 265/30-19 in the rear.
#3519
yes they did, bought them off another cl member, the tread on the fronts is still 50% with the yokohama advan sport, the rears came with 265 35 19 but low on tread. I've never bought rims before so im a noob at this stuff
did this come off an IS-F? typically IS-F's run 40-series up front w/ oem treadwidths. 2is's run 35-series based on oem treadwidths.
try 265/30-19 in the rear.[/QUOTE]
#3524
Got some new wheels I no I could find thee answer but don't feel like going threw every thread.. So my question is
19x9+20 215/35/19
19x10.5 +20 245/35/19
Will this b safe and will they hold air.. Not worried of fitment I'm rolled and pulled all around now
19x9+20 215/35/19
#3525
19 x 9.5 +12 Front / 19 x 11 +15 Rear
So my IS250 has been bone stock since I have had it (2008). It's time to give her a makeover. I found some used Varrstoen 1.1.2 rims with the following size. Do you think I will have a problem running the rear specs? I plan to get BCR coilovers and perform fender mods.
Front 19 x 9.5 +12 offset
rear 19 x 11 +15 offset
any insight would be helpful.
Thanks!
Thanks!
