Will those wheels fit? START HERE.
#3526
So my IS250 has been bone stock since I have had it (2008). It's time to give her a makeover. I found some used Varrstoen 1.1.2 rims with the following size. Do you think I will have a problem running the rear specs? I plan to get BCR coilovers and perform fender mods.
Front 19 x 9.5 +12 offset
rear 19 x 11 +15 offset
any insight would be helpful.
Thanks!
Thanks!
not recommended.
#3527
I just bought 215 we woll see what happends.. And I can't fit a 245 on the rear it rubs too much.. I'm trading for 235 on a 10.5.. Its not a daily will just drive to gym and back during week.. Maybe 3 hundred miles on weekends
#3529
I have done a lot of searches and haven't found a definitive answer yet. Any help is appreciated.
I have a 2011 IS350 AWD and I just put on Avant Garde wheels. They are 19x8.5 +35 all around with Hankook V12's in 235/35/19 all around. No rubbing right now that I can tell, but it gets super close in the front when turning.
I want to put on F Sport springs, but I'm worried there will be rubbing and I don't really want to deal with any mods to fix any rubbing. I don't even want to do the heat gun mod if possible. The place in the wheel well where it gets really close when turning looks like it would free up some space a bit when lowering about an inch, but I'm not sure.
Anybody have this exact setup and if so, is there any rubbing?
Thanks!
Thanks!
#3530
but everything that's bolded in your post will work fine.
Thanks!
Thanks!
having said that, have you considered 245/30-19?
#3531
i'm not sure what you're asking.
i would've suggested that you go with 225/35-19, but seeing as to how you have an IS350 AWD (the stranger, not-as-popular cousing to the RWD variant) you should definitely get as much treadwidth as you can for it.
#3532
here's the thing; you're running a tire size (235/35-19) that's over 3/8" taller than them oem size (225/40-18). if you're going to be running taller tires, you're bound to have rubbing issues with the tire and the fender liner.
since getting different-sized tires is not an option, you either heatgun the liner or let the tire rub a hole in the fender liner.
your choice.
#3533
225 on 8.5" doesn't have a "stretched" look, but that's a moot point.
your choice.
your choice.
I might be ok to heat gun the liner, I just don't want to have to do more than that. Is that as bad as it would get? Are you speaking from personal experience? I really appreciate your feedback, it's just really hard to get straight answers on here because there are so many posts and so many opinions.
#3534
You are right, it wouldn't be as stretched as a lot of setups on here, but i decided it is still more than I would like. Just letting you know my basis for my tire size decision.
