Will those wheels fit? START HERE.
Old 06-03-12, 05:59 PM
  #3556
projectdna
projectdna's Avatar
Originally Posted by bowenn13
Work Schwert SC1's
19x8.5 ET32 5x120 fronts
19x9.5 ET35 5x120 rears
Will these fit my IS250? I'm planning to get the car dropped by atleast 1.5" both front and back, am I going to to need spacers and fender rolling? thanks!
and I forgot to mention, these are the tires wrapped around the rims as of the moment:
Goodyear Eagle GS-D3
235/35/19
265/30/19
should not need fender rolling, but like laobo979 posted, that bolt pattern (5x120) doesn't work for the 2is (5x114.3).
Can I get a machinist to re-drill holes? I remember a while back I had wanted Avant Gardes in a non-Lexus fitted bolt pattern and the vendor selling the wheels simply told me they'd redrill the bolt pattern so it fits my car. Is it possible in this case?
you can, but you're compromising the original structural integrity of the wheels. any machine work that alters the structural integrity of the wheel should be given some serious thought.
Old 06-03-12, 07:57 PM
  #3557
bowenn13
bowenn13's Avatar
Alright, thanks for letting me know ahead of time before i made any rash decisions
I guess its back to the waiting game... Someone sell their sc1s or sc2s already!!!
Old 06-05-12, 07:19 AM
  #3558
Shorty9802
Shorty9802's Avatar
Rays g-games 77f
18x8 +30
18x9 +35
Will it fit 07 is350? And are they worth the buy?
Old 06-05-12, 09:19 AM
  #3559
projectdna
projectdna's Avatar
Originally Posted by Shorty9802
Rays g-games 77f
18x8 +30
18x9 +35
if they're 5x114.3 bolt pattern, then yes.
i would go with 19's to really show off the wheel faces, but that's an aesthetic decision. if you're looking to stay with 18's to keep running OEM-sized tires, i'd look at other selections. /$0.02
Old 06-05-12, 11:28 AM
  #3560
Shorty9802
Shorty9802's Avatar
Projectdna you seem to be a God on this thread, thank you. I was only looking at these because another member was selling them kinda cheap. I would rather have 19's also
Old 06-06-12, 07:18 AM
  #3561
jbone29
jbone29's Avatar
Default Need help
Just bought some Hankook V12 tires. About to order wheels. I will be running 225/40-18 in the front and 255/40-18 in the rear. The wheels i am getting are 18X8 in the front and 18X9.5 in the rear. My question is should i go with a +25 or +35 offset for the front wheels? I know if i go with the +25 it will give me a better stance but will it affect my driving. For the rear i should probably stay with the higher offset, correct?
Old 06-06-12, 07:27 AM
  #3562
kingz415
kingz415's Avatar
18x9.5 +22
18x10 +22
Was thinking of putting 235 for fronts and 255 for rears for tires.
The wheels currently on it is 225/245 i believe.
Planning to roll my fenders.
How well would these fit and what tire size would you suggest i run?
Old 06-06-12, 09:57 AM
  #3563
projectdna
projectdna's Avatar
if you stick with the higher offsets, it shouldn't affect your handling.
btw, 18x8 is OEM-sized up front.
Originally Posted by kingz415
18x9.5 +22
18x10 +22
you won't be able to pull off 235's up front. maybe 255's in the rear... maybe.
i'd stick w/ 225 and 245 for the fronts and rears, respectively.
Old 06-06-12, 11:28 AM
  #3564
ScottIS
ScottIS's Avatar
Default bbs18x8 35os fit 08 350?
thinking of buying a set of bbs ck's ive found a deal on. theyre 18x8 so ill need 20mm spacers in the rear i think. the wheels have a 35 offset. theyre coming off an is300. will they clear my breaks on the 08 is350? will that offset differrnce matter?
Old 06-06-12, 01:38 PM
  #3565
Hilary
Hilary's Avatar
Default Need help with offset
I tried to search for information on this thread with no luck. There are so many replies.
I have a 2006 IS350. I have not had it lowered or any modificaitons done on it yet. I found some wheels that I like, but they only come in 20x8.5 with a +20 or +38 offset and 20x9.5with the same offsets.
My car currently has a staggered setup on 17's and I like the setup.
Is there anyway I can make a combination work (and still look good) with these wheels? Does anyone have any pictures with their 20" setup with the measurements that go with them.
I am also looking at 19" wheels. Haven't decided between the 20" or the 19". The ones I like don't come in 19, but if I can't use their offset I will have to move on to a different set.
Old 06-06-12, 01:53 PM
  #3566
projectdna
projectdna's Avatar
before you determine if you need spacers or not, i'd give BBS a call and find out if those wheels clear the oem IS350 brake calipers.
go with +38 offset. you won't need fender modifications, and should be able to run at the very least OEM treadwith-sized tires (225 and 255 for the OEM 18's).
Old 06-06-12, 02:08 PM
  #3567
Hilary
Hilary's Avatar
Thanks PROJECTDNA!
I have heard that it looks better with a higher offset on the back. I don't know anything about this topic, but I plan to order the rims and tires online and I don't want to get the wrong fit.
Old 06-06-12, 08:07 PM
  #3568
DJSTYLE
DJSTYLE's Avatar
Need help on these. Volks te37sl 19x9.5 +22 / 19x10.5 +22..Thoughts and suggestions..
Old 06-06-12, 08:15 PM
  #3569
projectdna
projectdna's Avatar
i think they're nice wheels, but those specs have been covered through and through - they were popularized by varrstoens.
so, i suggest that you search through this thread and find out for yourself what you need to do to make them fit.
if you have any other specific questions, feel free to ask.
Old 06-06-12, 08:52 PM
  #3570
laobo979
laobo979's Avatar
Question im rolling/pulling my fender. The front i cant make a full pass as it hit the caliper on the is350. Those who use the roller do you take the caliper off?
Quick Reply: Will those wheels fit? START HERE.
