Will those wheels fit? START HERE.
#3616
Gonna get a set offered by BC. The HB29 hella concave. Trying to get as much concave a possible with only having to roll fenders maybe heat liner. How u guys feel about 19x9 and 19x10 both +33, or +35? Or should front be different than rear? Thanks
#3618
If I recall correctly, the consensus for tire sizes on 19x8.5 and 19x9.5 wheels when trying to match OEM rolling diamater, you go with 225 or 235/35/19 in front and 265 or 275/30/19 in the rear. Is this accurate? How about a 245/35/19 in the rear so that the sidewalls match better?
#3623
tire specs -> sidewall height, mm
front:
215/35-19 = 75.25
225/35-19 = 78.75
235/35-19 = 82.25
rear:
235/35-19 = 82.25
245/35-19 = 85.75
255/35-19 = 89.25
265/35-19 = 92.75
265/30-19 = 79.5
275/30-19 = 82.5
sounds about right.
#3625
tire size - rolling diameter:
front:
225/40-18 - 25.08" (OEM)
225/35-19 - 25.20" (OEM +1)
alternatively...
215/35-19 - 24.92"
235/35-19 - 25.47"
rear:
255/40-18 - 26.03" (OEM)
265/30-19 - 25.25"
alternatively...
235/35-19 - 25.47"
245/35-19 - 25.75"
255/35-19 - 26.02" (OEM +1)
265/35-19 - 26.30"
275/30-19 - 25.49"
bon appetit.
#3626
I was looking at getting a set of 2Crave Rims. Here were my two options I was thinking:
20x7.5 with a 225/30/20 tire (Both front and rear) Offset: ? That's the one thing Im not sure of. Prolly a +35 (Front and rear)
Or
Same set of rims but with:
20x8.5 with a 225/30/20 tire (Both front and rear) Offset: Same +35?
http://www.discountedwheelwarehouse....0FBL&pID=10393
My plans are to lower the car with H & R springs. Just curious which would be better for my future plans. Is going with a smaller rim in the front and staggering the back even worth it? Might as well keep them both 8.5 and have the ability to rotate right?
I dont want to roll the fenders or anything like that. I don't mind heat gunning the inner plastic tho Thanks for the advice/knowledge
Or
#3627
Need advice
My name is Henry
im kinda new to this form and i just got my Is350not too long ago i need advice.
i have 225/40/18 now for front and 255/40/18 for rear (I believe these are my OEM wheelspecs.)
i just got new rims
offset:35mm
hub bore :60.1
should i keep the size like that?
what ur recommendations.
i just got new rims
offset:35mm
hub bore :60.1
#3628
Thanks for all the info projectdna. Assuming I'm interpreting everything correctly, if I want matching sidewalls I would get 235/35/19 with 275/30/19 or 225/35/19 with 265/30/19. However, if I want closest to stock rolling diameter I would get 225/35/19 and 255/35/19, but the sidewalls would be way off (>10 mm difference). So I'm thinking I'll go with 225/35/19 with 265/30/19 (the smaller size should reduce rubbing as I understand it) and just deal with the rolling diameters being off ~3%, which I assume isn't that big of a deal.
For anyone interested, I compiled projectdna's data into a spreadsheet and included percent differences in rolling diameter from stock:
Tire Size / Sidewall (mm) / R. Diam. (in) / R. Diam. % Dif.
FRONT
225/40-18 / STOCK / 25.08 / N/A
215/35-19 / 75.25 / 24.92 / -0.64%
225/35-19 / 78.75 / 25.2 / 0.48%
235/35-19 / 82.25 / 25.47 / 1.55%
REAR
255/40-18 / STOCK / 26.03 / N/A
235/35-19 / 82.25 / 25.47 / -2.15%
245/35-19 / 85.75 / 25.75 / -1.10%
255/35-19 / 89.25 / 26.02 / -0.04%
265/35-19 / 92.75 / 26.3 / 1.04%
265/30-19 / 79.5 / 25.25 / -2.97%
275/30-19 / 82.5 / 25.49 / -2.14%
FRONT
REAR
#3630
Or
-url snip-
Or
-url snip-
running a staggered set-up is do-able, but if your 2is is AWD i'd save the headache and run a square set-up.
My name is Henry
i just got new rims
offset:35mm
hub bore :60.1
i just got new rims
offset:35mm
hub bore :60.1
yes.
should you get it?
up to you.
personally, i would go with a staggered set-up (wider wheels in the rear than in the front), and something wider than OEM specs.
-excel data dump snip-
btw, good work on the data interpretation. i thought i was getting too geeky for this thread.
wasn't this already addressed in your previous thread?
