Will those wheels fit? START HERE.
#361
hmm I have no idea too why I rub..but I'm positive that's the place the tire rubs the plastic part..
#363
and you are dropped with H&R, aren't you? If you have no issues with rubbing with H&R spring, I bet no issues too with Eibach250. Provided the plastic part is pushed in. Right? I have looked at your car at EOS and the drop was awesome.
#365
Didn't we already discuss this in PM's back and forth? You already know you are going to rub with those size wheels. Just accept it and understand that when you turn hard you are going to rub. You are not hurting anything. Lower your car, see where it rubs, heat gun in that part if it bothers you that much, and if it still bothers you after that, don't turn so sharp.
The car comes from the factory pretty dang close already. Once you start putting 19's and wider/ aggressive offsets you are going to rub. Get used to it.
Same with your lip. You are going to scrape it, get used to it.
cheers...
cheers...
#368
man.. I got 235/35/20 +38 front and 275/30/20 +43 rear..
the rear is perfect.. no rubbing there.. but the front.. damn.. I try the heat gun and i think I push have I can, but it still rub
and mine is not drop.. and thinking of dropping it., but then I know I would have more rubbing.
#369
I got 245/35/20's up front and im dropped on Tein S tech's and rubbing is a minimum. I rub in parking lots a little and when im reversing. No rubbing at all after that on a +38 offset rim and i have NOT done the heat gun mod yet.
#370
maybe i need to heat gun more......
#373
haha i'm dropped on megan coils, 3" drop...rubbin up in the front. i took a rubber mallet, a 6 pack of heineken, and a few hours to take off the wheels, heat gun the fenders and made it a lil wider for the turning and pushed in the plastic molding. minimized on the rubbing fo sho!
#375
