Will those wheels fit? START HERE.
Old 09-27-12, 11:21 AM
  #3856
ThreeFive0
ThreeFive0's Avatar
Could someone help me out with post #3848 please.
Old 09-27-12, 01:11 PM
  #3857
desiis250
desiis250's Avatar
Default Vossen VVSCV3
guys someone is selling Vossen VVSCV3 localy with this info:
Front-19" x 8.5", +30 Offset, 5 x 120.65 Bolt pattern. Rear-19" x 10", +22 Offset, 5 x 120.65 Bolt pattern.
what I want to know is if they will fit 2009 is250?
Thank You
Old 09-27-12, 01:21 PM
  #3858
maximL
maximL's Avatar
Thank You
Lexus IS bolt pattern is 5 x 114.3, so those will not fit without adapters.
  #3859
bob4256
bob4256's Avatar
Thank You
They will not fit on the 2IS. Our bolt pattern is 5x114.3
Old 09-27-12, 01:24 PM
  #3860
maximL
maximL's Avatar
Originally Posted by ThreeFive0
How would these fit on an IS350? I'm looking for a flush appearance. I plan on lowering the car 1 inch with an eibach pro kit just to close the gap between the tire and fender.
Front 20x9 +30
Rear 20x10 +40
Also, what tire size recommendations would you make?
Thank You
Those will definitely fit and should be flush looking with a mild drop. You may have to do some fender work though. As for tires, do a 225/30/20 up front and 255/30/20 in the rear as long as you don't have AWD. Make sure that the front wheel clears the IS350 brakes.
Old 09-27-12, 01:49 PM
  #3861
sleekbrian
sleekbrian's Avatar
Originally Posted by ArtG
thanks for the reply, could you please suggest what is a good specs for 18 and 19 wheels, lowered to 1/2 to no finger gap without fender mod??
if i not mistaken, 18x8.5 & 18x9.5 +30 to +40 and 19x8.5 & 19x9.5 +30-40 should be ok?? please correct me if im wrong. does the wheels width/ size even matters in this case?
sorry for the long post and thanks in advance
Those specs will be fine. Just dont choose too too wide of a tire or you might experience rubbing.
Old 09-27-12, 04:43 PM
  #3862
J2NICEE
J2NICEE's Avatar
Is it possible to tuck in the rear without fender mods? (sorry if this is a dumb question)
Old 09-27-12, 05:50 PM
  #3863
k4fu
k4fu's Avatar
19x8.5 +25 or +30
19x9.5 +25 or +30
225/35/19 265/30/19
roll the fronts for +25? would a +30 F be able to avoid doing so?
as for the rear, rear fenders are rolled, car sits at 25" ground to fender front and rear. it seems like the rear should be fine with +30, but would a +25 R require me to do a slight pull or shave?
Old 09-28-12, 03:47 AM
  #3864
JDMpeezy
JDMpeezy's Avatar
help!!! i have the f sport 19x8 & 19x9 rims with the lame *** oem tires. wondering what tires i should run with a stretch look but not way too aggressive, im also lowered on the f sport springs with shocks i do plan on roucking coilovers but its one thing at a time for now, this is my DD vehicle!
Old 09-28-12, 04:49 PM
  #3865
ArtG
ArtG's Avatar
Thank u for the reply
Old 09-28-12, 11:56 PM
  #3866
bogohead
bogohead's Avatar
i currently have 19x10.5 +22 in the rear with a 245/35 tire
but when i go up driveways my wheels tuck a little and it rubs
will at 19x11 +25 or +30 with a 245 rub?
will the rim stick out more? or go in more?
i just wanna make sure that it doesnt rub and make that horrible noise.
thanks!!
Old 09-29-12, 04:10 AM
  #3867
Silent53
Silent53's Avatar
Noob question but can i run this setup. My RWD is250 is gonna be dropped on RM springs which is a 2 inch drop but i was wondering if i could do this.
XXR 521's
front 18x10 +25 225/40/18
rear 18x10 +25 255/35/18 or should i do 245/40/18
both F and R wheels have a 3.5 lip
I really don't know what offsets and tire size will work. I'm a noob.
Old 09-29-12, 09:51 AM
  #3868
Vroomin350
Vroomin350's Avatar
Please do not stretch tires on 8 and 9 inch wide rims, specially that you are on springs and it will look horrible. I would stick to OEM LAME *** TIRES because your offsets aren't exactly aggresive.
thanks!!
With a +25 it will rub and most likely with a +30 as well, you need camber arms. Have you shaved the rear tabs?
XXR 521's
Too aggresive upfront unless you plan to roll/pull/shave front fenders and relocate the tabs. Rears should be good with a roll and pull.
Old 09-29-12, 11:33 PM
  #3869
bogohead
bogohead's Avatar
nope, i havent
will that extra half inch make the wheel stick out that much more?
cus with my wheels now, i really dont need much space for it to not rub
oh and if you can help me out with this too itd be great, i delted my front two tabs and now my bumper falls a loose and disconnects from my fender, how can i reinforce or fix this?
Old 09-30-12, 11:09 AM
  #3870
irulea2
irulea2's Avatar
Hey guys. I've searched a ton and can't get direct answer. I have the sport suspension on my is350 (don't know if drop is any different). I'm looking at 2 sets of wheels. I don't want to roll or pull fenders.
Forgestar f05
19x8.5 et 45 front and back
235/35/19
First will these clear BBK?
What's maxx offset for flush without rubbing.
or
20x8.5 et32
245/35r20
Rears 20x10.5 et30
285/30r20
Any help is appreciated.
Quick Reply: Will those wheels fit? START HERE.
