Will those wheels fit? START HERE.
Old 11-21-12, 09:38 AM
  #3991
bayarea508
bayarea508's Avatar
Default Will they fit?
Noob question
Width: 19x8
Offset: 50mm
What would these need in order to fit any IS?
Old 11-21-12, 10:01 AM
  #3992
Quik208
Quik208's Avatar
Nothing. They will be very sunk in. You doing those specs on all 4 corners?
Old 11-21-12, 06:51 PM
  #3993
aagad5
aagad5's Avatar
Just got a set of Volk TE37 time attacks fronts are 225/35/19 with 19x9.5+22 and rears 255/35/19 19x10.5+25 stock suspension what should i do rubbing a lot? should I just roll rear or add some camber into it with a roll?
Old 11-22-12, 11:44 AM
  #3994
i3urton
i3urton's Avatar
Default volk progressiv me
will these volk progressiv me clear is350 oem brakes?
19x8.5 +29 and 19x10.5 +4
happy gobble day everyone.
Old 11-22-12, 11:54 AM
  #3995
Quik208
Quik208's Avatar
Front will need to do bumper tab relocation heat gun the liner, and rub or cut a way part of the liner by the bumper tab. Rears will need to roll and slight pull. ( will naturally pull slightly from rolling) may also need to add slight camber depending on height.
Old 11-22-12, 11:55 AM
  #3996
Quik208
Quik208's Avatar
Yes they will fit.
Old 11-22-12, 10:41 PM
  #3997
i3urton
i3urton's Avatar
Originally Posted by Quik208
Yes they will fit.
just to be clear they will clear is350 oem brakes?
Old 11-22-12, 11:25 PM
  #3998
Quik208
Quik208's Avatar
Yes they will fit.
See above.
Old 11-23-12, 12:04 AM
  #3999
MyIS350G
MyIS350G's Avatar
Yes they will fit.
They will clear you brakes but unless u r running camber kits in the rear or else you ain't gonna be able to run the 10.5+4
Old 11-24-12, 01:14 PM
  #4000
pmanliu
pmanliu's Avatar
Hope everyone had a great thanksgiving.
Found a set of VMR v710's coming off an Acura TL.
Offests:
19x8.5 +35mm w/ 225/35/19
19x10 +25mm w/ 265/30/19
Fronts look okay but im confirmed about the 10 R and if it will fit/rub. Lowered on Tein S-Techs and not looking to run negative camber. Will this fit? Thanks in advance!
Old 11-24-12, 05:22 PM
  #4001
monkeyg35
monkeyg35's Avatar
Front tire size is to big.
Oic... thanks!!!
Would this fit for a 2nd gen GS?
Old 11-25-12, 05:57 AM
  #4002
pmanliu
pmanliu's Avatar
Offests:
Bump... any advice would be greatly appreciated. Planning on checking out these rims in person later but its a long drive...
Thanks in advance!
Old 11-25-12, 09:22 AM
  #4003
Quik208
Quik208's Avatar
Thanks in advance!
Specs on the wheels are good, and tire size are perfect. You will need to roll the rear fender, but other then that you will be fine.
Old 11-25-12, 12:21 PM
  #4004
Jenuine10
Jenuine10's Avatar
stocks were 17in already no? so think prob fit 17-19in?
Attached Thumbnails Will those wheels fit?  START HERE.-img_2530.jpg   Will those wheels fit?  START HERE.-img_3052.jpg
Old 11-25-12, 05:33 PM
  #4005
SCWB
SCWB's Avatar
Thanks in advance!
You won't be able to get away with rubbing in the rear with that spec and tire.
Either choose narrower tire or mod the rear fender.
Quick Reply: Will those wheels fit? START HERE.
