Will those wheels fit? START HERE.
#4054
#4058
the correct size to run in the rear is 275/30-19.
rule of thumb is, for every two sizes wider you go, you go down one aspect ratio.
in this case, the OEM +1 size for the rear would be 255/35-19. going two sizes wide (275), you'll need to reduce your aspect ratio to 30 to stay as close to oem rolling diameter.
again, 275/30-19.
#4059
wrong and wrong.
again, 275/30-19.
again, 275/30-19.
If he wanted to he could run a 275/35 and not have any problem. Speedo may be a little off but other then that op would be fine.
#4060
and that doesn't include how the traction control system would react, since it bases its readings on individual wheel speed sensors.
just because it can, doesn't mean it should be.
#4062
Looking to change up my set up next year, how much guard work is necessary to fit the following:
19 x 9.5 +30 front and 10.5 +30 rear? Would 225 and 255 be appropriate? Will be lowered on BC coils.
Thanks
Thanks
#4063
Thinking about buying some wheels from a friend 19x8.5 +27 front and 19x10 +29 rear. Sitting on Teins with about a 1inch finger gap. Does anyone have suggestions on tire size. Are any mods needed besides fender roll?
#4064
Rear: 255-35-19 (moderate risk of rubbing) or 245-35/19 (small risk of rubbing)
#4065
Got a deal on wheels and tires. Just want to make sure it should all fit!!!
Wheels are 17x8 +25 Front and 17x9 +42 Rear
Tires are 225/45/17 Front and 245/45/17 Rear
Should be a pretty straight forward fit right?
2006 IS250 RWD
2006 IS250 RWD
