Will those wheels fit? START HERE.
#4096
This is it, and what you can expect for yours to look like as we had very similar specs
#4097
Need to get 2 front tires on stock is250, Currently have lc818, They rub slightly and im not happy with the height of the sidewall. Currently 235 35 19, Id like to go with 225 40 19 or 225 45 19. Would this be fine? Just want a little more rubber on the sidewall bc i dammaged one wheel already.
You're going to run into significant rubbing due to the increase in inches on the 19" wheel even without being lowered. If lowered, this would require significant fender work.
225/40/19 however is only a difference of 2.34%. You're still running the risk of sidewall damage due to a decrease in width, however your overall diameter is only increasing by 0.61", sidewall height increase by 0.31", and radius increase by 0.31", which translates to an overall circumference increase of 1.93".
Depending on your suspension situation, this may prove to be a problem. However, it is likely that this set up still is not recommended due to possible rubbing even on stock suspension.
The 235/35/19 is the most optimal tire size unfortunately. As it has been used by many members on the boards that have 19" wheels, both lowered, and stock suspension height. If you wanted a thicker tire, it may be wise to move to a 18" wheel.
MODS: Would it be possible to have these tools be stickied? I've been using them to help with these questions, and I find them VERY useful.
Offset calculator: http://www.1010tires.com/WheelOffsetCalculator.asp
Tire Size calculator: http://www.1010tires.com/tiresizecalculator.asp
#4098
Need some help. I think im about to rub like crazy!
I am putting on 19x10.5 +22 on the rear with 275/30/19. How low can I go? I dont mind rolling and a very slight pull and even taking the liner out. I would like to go quite low with my coilovers, but I would like minimal rubbing.
#4099
#4101
I agree with Rookie. That is the optimal setup for his specs on the wheel. one thing to pay attention to though is when buying a 245 trie for the rear make sure the load rating matches the car. I bought 245/35/19 tires for my 10.5 rears only to find out the load rating is 93 and the car calls for a load rating of 95 for the rear. This might not matter to most but it is a huge worry to me. My 10.5 rears are only +30 so Im planning on getting some 255/35/19. im sure it can be done on the +22 also with some negative camber and a fender roll.
#4102
you're simply not going to get away w/ 275's on a 10.5"-wide wheel w/ +22 offset. 245's are your best bet in terms of clearance given those wheel specs.
and i don't understand why this needs confirmation when it's the umpteenth time it's been covered in this thread. please use the search function.
#4103
Thanks guys, i appreciate it.
Ok, I read a few posts concerning 10.5 rear wheels. 245/35/19 seems to be the norm just as you all have stated, (thanks for the responses by the way). I have also read that running such a stretched tire isnt good for the sidewalls of the tire. So, can I run a 255/30/19 if I put some Megan arms on the rear? Or not lower it to a no-gap ride height?
#4104
the only problem w/ a 255/30-19 is that its rolling diameter is not within OEM spec, and will cause your speedometer and odometer to read incorrectly.
the 2is traction control system also won't like it, and i'tll let you know.
if you wanted to run wider-than-OEM-sized tires, a 10.5"-wide wheel w/ +22 offset will not accomplish that.
#4105
it's not an unsafe stretch, if that's what you're implying.
#4106
not necessarily a fitment question but I just got a set of wheels recently and went ahead and rolled all 4 fenders and shaved the front bumper tab but didn't completely remove it. I just shaved most of it down, hopefully that will be enough
anyways, my question is, do you guys remove the plastic fender liner completely in the front? because that leaves the whole set of wires exposed in the wheel well towards the front? have any of you had problems with the wires being more exposed??
#4107
Probably the most asked questions here. And now i have to ask one. I have read through the Fitment Thread on CL etc.. But, my specific setup i am looking at seems a little different but i think i should be fine. Question is, will i need to roll or cut my rear fenders with this setup and do the tires seem like a correct size?
Front: 19x8.5 +30 offset and 245/35/19
Rear: 19x9.5 +25 offset and 275/30/19
Any input or even just a "they should fit fine" would be greatly appreciated.
#4108
#4109
go w/ 225/35-19 + 255/35-19 plus rolled fenders.
