Will those wheels fit? START HERE.
Old 02-06-13, 07:54 AM
  #4246
RVCAis250
RVCAis250's Avatar
Originally Posted by Hrmnd
I`m keeping it at the sport suspension height which I believe is 0.4 inches lower in the front and no change in the rear.
The specs are mildly aggresive. You'd be fine at that height if you don't go lower. If you do go lower you just need a roll.
Old 02-06-13, 10:44 AM
  #4247
hhss
hhss's Avatar
Thanks for the insight !
Old 02-07-13, 03:44 AM
  #4248
Silent53
Silent53's Avatar
20x8.5 +20(Front) 225/30/20
20x10 +25(Rear) 275/30/20
will it work?
i'd be dropped on Megan EZ. WOuld i have to do alot of camber adjustment in the rear?
Old 02-07-13, 08:57 AM
  #4249
Scless
Scless's Avatar
Will this work for my IS350 AWD? Not really trying to ruin any of my AWD functions. Don't want to do any fender modifications.
19x9.5 + 0 front and 19x10.5 +10 rear. Work VSXX rims.
Old 02-07-13, 09:17 AM
  #4250
RVCAis250
RVCAis250's Avatar
will it work?
Would it work, yes. You just would need to do some fender work to make them work. And first off, I think those spec rims with those tires are too much. I think the tire is too beefy and it would work much easier with at least a mild stretch like 265/30 or 255/35. You'll need to roll and pull your rear fenders. Just roll on the fronts. After that, it depends how low you are and how wide of a tire size you go with
Old 02-07-13, 09:19 AM
  #4251
RVCAis250
RVCAis250's Avatar
You can't get by with those specs without any major fender work. Those are some really aggresive wheels to put on our 2IS.
Old 02-07-13, 12:17 PM
  #4252
Silent53
Silent53's Avatar
If I opt for 255/35 like you said with that mild stretch will i be flush after a fender roll in the rear?
and the 225/30 front is fine with just a fender roll?
Old 02-07-13, 12:29 PM
  #4253
RVCAis250
RVCAis250's Avatar
Yeah you'd be pretty flush. Just about as flush as you could get w/o major fender mods or camber kits.
And the front you'll be fine with a roll. It'll naturally give you a slight pull cause the fenders aren't as strong as the rears, so you will be fine unless you go really low then you may run into problems with the tabs but I think you should be fine.
Old 02-07-13, 07:44 PM
  #4254
soFreshIS
soFreshIS's Avatar
Picked up set of 20inch Vip Modulars VR-08
Will be here next week
now i need tires!
whats size u guys think i would need?
they are 20x9 and 20x10.5
offset is in the 30's
Im Running Tein CS Coilovers
Would 225/35/20 and 255/35/20 be my best? or which u guys perfer for not much fender work?
Thanks
Old 02-07-13, 08:04 PM
  #4255
ethegent
ethegent's Avatar
I saw the AWD "will this fit" thread but it seems like the traffic flow there is dead.
If you can please tell me if this would fit my is250 AWD without fender work and ruining my AWD, I would greatly appreciate it.
20x9 +38 (235/30/20)
20x10.5 +42 (275/30/20)
Old 02-07-13, 09:19 PM
  #4256
Scless
Scless's Avatar
Thank you for the reply. I'll keep searching for some rims.
Old 02-07-13, 10:13 PM
  #4257
VIPISO460
Registered User
VIPISO460's Avatar
Will this work with rolled fenders, am concearned of the front..
19 x 9.5 +45 all around for IS250 AWD?
Dropped on BC Coils
mated to
225 / 35 / 19
Lemme know am shopping for tires thanks!
Old 02-08-13, 07:09 AM
  #4258
Scless
Scless's Avatar
Hi again, I'm looking at 20x9 + 13 all around. Will 20s rub on my stock suspension? Will they fit without fender modification? Thanks again
Old 02-08-13, 08:13 AM
  #4259
RVCAis250
RVCAis250's Avatar
Yes. It will rub and you'd need a fender roll if you stay at stock height.
Old 02-09-13, 11:54 AM
  #4260
tonnetje
tonnetje's Avatar
Default will this work on IS250
my IS250 is lowered 1,3inch-30mm front/rear
i want those tiresizes on my rims
in front 235/35/19-8.5j -offset35
in rear 285/30/19-9.5j- offset 35 or 40
does it rub in the rear or sticking out with this offset ?
anybody have pictures with this offset in the rear?
in the front no problem i think but in the rear i dont know
anybody who know the answer please leave a comment
pictures are great to
greetz tonnetje
Quick Reply: Will those wheels fit? START HERE.
