Will those wheels fit? START HERE.
#4306
It all depends on the tire sizes you go with. I'd personally go with 225/35 and 245/35. With that said, if you don't go lower you should be fine. If you go lower,you'll need a roll and a natural pull
#4307
PS: tire size is 225 40 19 and 245 45 19
#4309
So I have been doing a lot research my wheels is 19x9+35mm, 19x10+35mm for 2IS. Most people go with 225/35/19 and 255/30/19, just wonder is it going to be safe on the road and no rubbing? I’m thinking to go 235/35/19, 265/30/19 please help
#4310
As far as rubbing, it depends how low you are or will go.
#4312
19x8.5 +38 front
19x9.5 +42 rear
2 questions (AWD Fitment)...
(1) From the looks of it, the rear will be pretty sunk in. What size spacer should i run?
(2) Also can someone recommend an AWD tire setup? Car will be dropped on tein s techs, and i would like to avoid rolling fenders. However i also need some protection against the NYC potholes.
Thanks!
19x9.5 +42 rear
Thanks!
#4314
2. 215/35-19 + 235/35-19 for those brave enough and need the clearance, 225/35-19 + 245/35-19 for those not looking to run anything past a mild stretch.
#4315
thanks for the reply! but what do you mean brave enough and need the clearance? im going on coilovers but im not gna dump it to the ground or anything
#4316
19x8.5 +38 front
19x9.5 +42 rear
Thanks!
19x9.5 +42 rear
Thanks!
#4317
I would suggest getting wheels that fit the way you like rather than get spacers. However if you're sold on these wheels I would run a 10mm spacer in the front, and a 10 or 15mm spacer in the rear. Goodluck
#4318
This is my car on stock 17s
So as a refresher, I'm wanting to put on the following:
Front 245/40/18 on a 9.5" wheel +30
Rear 265/40/18 on a 10.5" wheel +30
Thoughts? Fender rolling required?
#4320
