Will those wheels fit? START HERE.
#4352
yes.
there's no way you can run those tire sizes without damage to the fenders/tires - especially the rear.
you'll need modified fenders to start, and run narrower tires. 225/35-19 + 255/35-19 come to mind, but 245/35-19 will have more clearance.
if you don't roll your fenders, yes, you will run into fender rubbing - front and rear.
What are your thoughts on this spec
work vsxx
19x9.5 +29 235/30/19
19x10.5 +29 295/30/19
Which set up would match my cars better? What would be required to run this set up?
THanks for your help
work vsxx
#4353
#4354
in the rear, 18x9 +38 will not need fender work, 18x9 +28 may (depending on your tire size), and 18x9 +15 will.
i recommend higher offsets to avoid fender work and/or to have to run narrower sized tires for clearance. also, higher offset wheels can allow you to run wider tires. anyone who's driven the 2is aggressively can tell you that the OEM tire sizes leave a lot to be desired.
#4355
I have a set of 18x10 5x114.3 +12 offset. Does anyone know if ill have to rub my fender even if its not dropped? And a good size tires i should get? im afraid the width might be to long and i just wanna know how itll fit if it doesnt fit .
#4356
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
What about a 1" drop via F-sport springs ?
19mm rear and 25mm front
Will that work with this proposed setup?
Thanks again
#4357
What would you guys run in an is350? 18 inch? 19 inch? My goal is to get a slightly wider stance on the car but i prefer maximum amount of tires in the rim not a fan of the stretch. I'm in the market for tires and just want to make sure I'm headed in the right direction
#4358
it's personal preference. obviously the size of the face of the rim has nothing to do with how wide it is. So you can stick with 18's and do a staggered setup with 18x9 front and 18x10 in the rear. Tire sizes will matter once you actually have the specs of the rims, otherwise there is no point telling what spec tires you should get.
#4359
235/35-19 with a fender roll.
the width is fine. it's the wheel offsets that, in this case, force you to run some thin tires over wide wheels aka "tire-stretching".
if you want as much tire as you can stuff under the fender sheetmetal, here's a few rules of thumb.
1. given the same wheel diameter and width(s), high offset > low offset for "max tire"
2. wider is not always better. the wider the wheel, the smaller the range of tire sizes you can fit.
3. buy a set of wheels to fit the car, not vice versa.
#4360
#4361
the 225/40-19's are OEM size for the IS-F, but they're one aspect ratio size taller than what would normally be for the 2is. what you should have opted for is 225/35-19 in the front. however, that's not to say that 225/40-19 won't work...
as you posted, yes, just heat the plastic and push it out of the way.
again, my apologies.
#4362
before going further, i have to apologize for not reading your initial post correctly. i misread it and was under the impression that you were asking about 18" wheels and not 19" wheels - which you have.
Ok , but going to 225/35/19 will have a significanly lower sidewall height.
And lower than rear sidewall. 255/35/19
Won't that be worse ?
With the setup I spoke of earlier will an f-sport drop be a problem?
Fender above the tire seamed to have some clearence.
Maybe keep in mind that ride quality is my concern.
Thank you for your help
#4363
Thanks again no problem ,they were just trying sizes ætla the tire shop.
Won't that be worse ?![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Thank you for your help![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
with the set-up you referenced, you won't have a problem w/ f-sport springs in terms of clearance. your ride quality should firm up a bit but not get washboard stiff (or worse, sloppy).
#4364
the difference between 40-series and 35-series for 225's in 19 is ~11mm. since you're looking to run pilot super sports, you shouldn't lose too much of your ride quality - PS2's have slightly softer sidewalls.
19x8 +35 225/40/19 for front
19x8.5 +35 255/35/19 for rear
I like the idea of a little more rubber around my wheels
Also not sure about the drop due to i'm in Iceland
So will rear be OK? Fender rolling possibly ?
F-sport springs at later time maybe.
Thanks
