Will those wheels fit? START HERE.
#4397
is350... 19x8.5 +30 F 19x10.5 +38 R stock hieght. soon to be on coilovers lowered enough for no gap. linea corse lemans..thats for that set and what about
19x8.5 +35 19x9.5+40 . any mods? just trying not to do any fender work but just want to be low enough to clear the gap. thanks!!!
#4399
#4400
Hey guys i have a bone stock 2009 is 250 6MT RWD and saw a great deal on kijiji and wanted your opinion if they would work.. they are TI – TiRM's 19x9 +25mm offset all 4 wheels, tires are 245/35/19 in the front and 275/35/19 in the rear.. this guy had them on his 350Z and they look fantastic as they are charcoal black and my car is MRM. Would these fit right in and work fine without any rub or problems or would there be modifications needed?
thanks
thanks
#4402
Fronts will have to be rolled with fender liner trimmed and bumper bolt relocated with a 225/35 tire
Rear will have to be rolled with a slight pull and bumper bolt relocated. Tire would be either a 245/35 or a 265/30. I personally would go with the 265/30 option for the rear
#4403
Would I be able to fit a 235/35/19 on the front?
#4404
2007 Lexus IS350, lowered on F-Sport suspension
Concept One RS-8 Wheels
19x8.5 +38
19x9.5 +42
Fender roll maybe? I need tire recommendations also...225/35 and 265/30?
19x8.5 +38
19x9.5 +42
#4405
Depending on how low you are you might be able to get it to fit with some negative camber. Also I would fit the rears and see how much you need to pull from there. You can also just dial in some negative cmber in the rear if you get a camber kit
#4406
No fender modifications needed and your tire specs are right on point. I've ran a similar setup but slightly more aggressive with no modifications needed. You could go more aggressive without moddinfg fenders if you want, or you can stay with your current specs for a more conservative fitment.
#4407
07 IS250 AWD
lowered on tein s
Varrstoen 3.3.2 19x9.5 +20 offset
Would these fit without rubbing or any problems?
(Sorry im still new to the whole modding cars)
Thanks in advance!
lowered on tein s
Thanks in advance!
#4408
All the above is assuming you run 265/30 as mentioned before.
And you can fit 235/35 in the front, it'll just make it that much more of a b***h through bumps and turns. That less 10mm makes a huge difference. Obviously it depends on how low you go. If you plan on dropping it to cover the gap or even start slightly tucking, then I'd stick with 225's
#4409
Has anyone fit Linea Corse Lemans 18x8.5 +45 225/40 and 18x9.5 +30 255/40 on an IS350? What would the rear look like with the +30 offset?
I'm lowered about F-Sport springs height.
Thanks!
Thanks!
