Will those wheels fit? START HERE.
#4456
#4457
I'm looking to buy some TSW Mugello
Rim sizes are:
Front: 18x8.5 +40offset
Rear: 18x9.5 +40 offset
Will they fit without fender work?
And what tire size can I run with them? (Can I use my stock tires)
I am at stock height not lowered at all.
Rim sizes are:
#4458
19x8.5 ET+ 40 Front + Rear. Will these fit with 225/35 front and 265/30 rear?
I tried calculate it and it seems to fit but want to be sure..(?) Dont know the name of the rims. Original springs.
#4459
but if you really want to take a chance, you'll have to roll all four corners flat, shave the rear fender tabs down, and remove the front fender tabs altogether. 225/35-19 + 245/35-19. nothing wider unless you want to pull your fenders so far out that you might as well get new fender sheetmetal.
should be fine.
#4460
Rim sizes are:
Rim sizes are:
yes, you can run OEM 18" tire sizes w/ those specs.
front: 235/40/18
Rear: 255/40/18
#4462
short answer is yes.
however, technically speaking, OEM stock 18" front tire size is 225/40-18, not 235/40-18. whoever told you the latter was a stock size is wrong.
#4464
im really interested in these.. would they fit?? 07 is350. mainly worried about trying to clear the front calipers.
http://www.ebay.com/itm/JDM-Work-19-Varianza-T1S-5x114-VIP-acura-honda-lexus-infiniti-/190822166702?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c6de330ae&vxp=mtr
Work Variazna T1S
19x8 + 43
19x9 +48
Work Variazna T1S
19x8 + 43
19x9 +48
#4467
Im very terrible at this , I would like to purchase BBS rims LMS preferable they are reps. My only concern is whether i should get 19" or 18" thats my only concern . Once i have purchased those rims what else should i know because i plan on dropping the car later on. So before i drop it off what information should i know and what size tires shoud i get ? Im new at all this and how should this offset stuff work.
Thanks alot !
Thanks alot !
#4468
you will definitely need to mod your fender tabs (shave rear, bend flat front + remove fender bolt).
do not go w/ megan EZ's for aggressive-fitment wheels. megan EZ spring rates are too soft and allow too much suspension travel.
225/35-19 + 245/35-19 is the widest you can run.
215/35-19 + 235/35-19 will give you the most fender clearance.
Thanks alot !
Thanks alot !
1. wheel specs: diameter, width, offset
2. proposed ride height
#4469
i have 225/35/19 in front. and 245/35/19 in rear. I want more tire strech so i can get camber little closer to stock without rubbing quarter panel, and to expose more wheel lip. I'm thinking of either getting 235/35 or 225/40 ive never seen a 225/40 so i dont know if it looks like a bit to much sidewall or not. which tire do you think would look best? or do you think you could even tell by looking at them? thanks
#4470
Hey, I am a noob at this stuff. I'm planning on getting some wheels pretty soon. They're offered in 19x8.5 +15 19x10 +20 and 19x8.5 +32 19x10 +38. I want a semi agressive set up with minor fender modifications. Will need help with tire sizes too please.
