Will those wheels fit? START HERE.
#4532
i agree the best solution is to get 18, but i just got my 19, trying not to spend too much....
thinking about 2 options:
1. 235/35 f and 265/30 r , OR
2. 225/40 f and 255/35 r ( stock isf size if not mistaken)
do you think the above option will make any difference?
otherwise i'll sell my 19 and get some 18
thanks
thanks
try 225/35-19.
#4534
Hey CL. Recently came over to Lexus from an 8th Gen Civic. I was looking into getting some wheels with a moderately agressive offset, but not too agressive in width. With looking to install coilovers sometime in the near future, I was considering a 19X9.5 et +12 or +22.
Questions:
-what fender modifications would be required if I would like to stretch the tires and tuck a bit with given specs?
-do you guys suggest a square set up with either offset, or staggered?
Any other suggestions and help is greatly appreciated. Thanks in advance!
Questions:
#4536
Questions:
Questions:
2. either or. square for AWD 2is's, staggered for RWD 2is's.
i don't know. will the fronts clear the front brake calipers?
#4537
Will these fit?
18x9 inset +7 R disk, 3 inch lip , tire size 225/40r18
18x10 inset -3 O disk, 5 inch lip , tires size 255/35r18
Also 19x9.5" +36 R disk fronts and 19x11.5" +48 O disk rears
Thanks for any help
Thanks for any help
#4538
Thanks for everyone contributing to this thread, I've tried searching through it and read most of the posts to what I wanted to ask but wasn't able to come up with a concrete conclusion...
I have the following right now on my IS250 AWD and haven't had any rubbing yet...
19x8.5 +35 235/35/19
19x9.5 +35 275/30/19
I'm wondering if it'll rub (and need fender mods, etc) if I was to install H&R springs
Thanks!
Thanks!
#4539
Thanks for any help
Thanks for any help
note that the combination of high offset and 11.5" wheel width may cause INNER clearance (w/ rear suspension components).
both sound like work wheels (which other manufacturer uses "R" and "O" disk designations?). i'd give them a call.
Thanks!
Thanks!
#4540
Auto Detailing Master
So first off, I apologize for asking this question because I am sure it has already been asked and answered several times... I will be honest though, I'm too lazy to read through this thread to find it so I figured this will just be quicker. Don't hate me
I am currently lowered on Megan EZ's as pictured below
Looking to get a set of 19" wheels sometime in the next year. I want them to be as flush as can be with NO fender modifications (except maybe heat gun mod), NO tire stretch, and NO rubbing.
What I would like to know is if I run either a:
19x8.5f/9.5r - what would be the best offsets and tire sizes
19x8.5f/10r - what would be the best offsets and tire sizes
I figured I would run 225/35/19 on front, 265/30/19 on rear (or 275/30?) so I'm more concerned on the best offsets for the given wheel widths above.
Thanks for the help! Again, sorry for what I'm sure is a repeat repost.
-Zach
-Zach
#4542
-lazy post snip-
-Zach
-lazy post snip-
-Zach
"search is your best friend."
there is a chance that it might rub when the suspension gets unsettled - moreso for the rear due to the tire size.
#4544
it also would have taken me less time to type this:
see above.
(had you actually paid attention to some of the posts on this very same page instead of hacking out a self-deprecating post along w/ a self-serving pic of your 2is, you would've noticed that there are at least two other posts that are asking questions about 19x8.5/9.5 set-ups.)
if you're too lazy to search, i'm too lazy to re-post.
#4545
Not too lazy to search, that is not what I said... Too lazy to read through the entire thread. I tried searching for "no stretch" "no fender modification" "no stretch offset" and saw a few posts but nothing with exactly what I was looking for. Seems like I may have caught you on a bad day or something since it appears you are often the most helpful person in this particular thread. Maybe someone else will chime in and help me out if they happen to have an answer... If not, simply not responding is much more considerate than a rant/lecture. Sorry to have upset you.
Also, I did read the particular posts on this page you are referring to... Neither of them are the question I was asking. They are both useful information, and I have taken note of that, however it did not answer my question.
