Will those wheels fit? START HERE.
#4666
So I'm stuck with deciding on size of the rims. I know I want 8.5 in the front and 9 in the rear with +35 front and +30 back.
I plan on 1 to 1.5 finger gap from the tire. What would look better 18"s or 19"s
I just dont want the 18"s looking to small (Which the current f-sports look like) or the 19"s being to big for that kind of drop.
Rims will be WORK VS-XX
#4667
#4668
hey guys looking to get some new rims for my 2006 lexus is350 sgm will be orange next summer so looking for a black rim please reply with some pictures/suggestions of what rims to get
#4669
Hey guys I'm planning on getting new rims for my car pretty soon but have a few questions I've been struggling with. I want both my front and rear set of tires to sit as flush as possible with my fenders. So my question is can I run 18x8.75 with a 20mm offset in the rear and 18x8.75 with a 33mm offset in the front without any fender mods or rubbing? If so, what are the best tire size I would need to get? I have an AWD IS250 by the way.
#4670
Do you guys think the setup below will be OK? I want to be flush don't want to be poking or rubbing.
I have an 08 IS250 RWD lowered on Eibach Pro Kit (1.4 front - 1.0 rear)
WEDSSPORT TC105N RIMS
FRONT 18X8.5 +32 WITH TOYO PROXES T1 SPORT 235/40ZR18
REAR 18X9.5 +35 WITH TOYO PROXES T1 SPORT 265/35ZR18
#4672
I am running:
19x8.5 +35 with 235/35/19
19x9.5 +35 with 255/35/19
Lowered 1.5" front and rear with BC Sports.
Go with this set, if you aim for 18" wheels with flush but without poke and without (major) rubbing.
#4676
curious about what specs you'll be running in the back... but as far as the front, you'll need a fender roll with some natural pull (you may need more of a pull depending on how low you sit) and you also need to relocate the fender/bumper tabs in the front. If you're gonna ride really low then you may have to bend that fender tab in a little bit. You'll see what I mean if you look inside the fender well.
#4677
This should be a very good set up for moderate flush, no poking, no major rubbing. You will rub very slightly on the fronts under extreme dips and hard turn, I am quite sure. The rear should clear the fender, but it will be very close. I answer based on my own experience which is comparable to your setup.
I am running:
I am running:
#4678
#4680
Hello everyone,
I just got the 3IS IS250 two weeks ago. I am so excited and love Lexus IS so much.
I am planning to upgrade 18 inch wheels with stock suspension. I may lower the car for 1.5" max in the future.
Can anyone advise what is the best offset for 18x8 front and 18x9 or 18x9.5 rear?
I checked out the Rays Wheel website. It claimed the 18x9 offset +30 can fit the IS.
I heard some people said the best will be near 40 offset.
Anyone fit the Rays 57FXX in their IS? Would 18x9 +30 or 18x9.5 +38 fit the rear better?
Any professional opinion? btw, I am not planning to mod the fender.
Thanks so much!
Thanks so much!
