Will those wheels fit? START HERE.
#4696
I'm really diggin these wheels.
http://www.ebay.com/itm/ENKEI-RAIJIN...968802&vxp=mtr
Would they fit our car? Bolt pattern seems to coincide with what I've seen in some posts. If they do, has anybody tried these rims?
Thanks,
Veach
Thanks,
Veach
18x8.5 +35mm, 225/40/18... thinking maybe i should have went with 235/40 instead, oh well. Just wanted to confirm, 235/40/18 will fit with no rubbing problems right? Lowered mildly on tein s-tech's.
#4697
Hey all,
Been trawling around these forums for a long while & got a lot of good advice.
This is my first post as it will be pretty specific so be nice![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
-ANYWAYS-
I have a ’06 Is250 Prestige RWD (Aus delivered)
Looking at getting a set of Varrstoen ES3’s (called 3.3.1 in Aus) with tyres.
Specs are:
Fronts –
18”/9.5/5x114.3 +22 Offset
P Zero Nero GT 225/35/18
Rears –
18”/10.5/5x114.3 + 22 Offset
P Zero Nero GT 245/40/18
Other offsets available are : +12, +22 & +30
Will these rims fit? Happy to roll guards etc. Worried about running a 9.5 in the front....
With the tyres – does anyone have any other recommendation of sizes or brands to be running?
Thanks all,
-ANYWAYS-
Specs are:
Fronts –
Rears –
Thanks all,
#4699
Let me update my question..
Will I be able to tuck my tires in the rear with a 20x11 +30 with no added aftermarket camber. Plan on going with 275/30/20 for tire size. Will consider 265/30/20 if it helps and allows me to tuck
#4700
So I ordered rims
(Conservative specs)
19x8.5 +32
19x9 +36
(Forgot the disc types but the rear will have a bigger lip)
I'll be lowered on FSport springs
Not sure what tires to get, I was thinking 35 series at least. Any suggestions?
19x8.5 +32
19x9 +36
#4702
hi, i found some volk progressive M.E. im wondering if it will fit my is350 lowered on f sport springs.
the wheels are 9.5 front w/ 245/35/19 and 10.5 rears w/ 275 35 19. unknown offset at the moment.
will this look funny or rub? thanks in advance.
#4703
you can go 235/35/19 front and 255/35/19 rear. No problem of rubbing. Front might rub just very little every once in a while but you wont notice it.
#4706
Will this rub:
18x8.5 +25 Front
18x10 +25 Rear
http://www.nlmotoring.com/XXR-521-Wh...7.htm?CartID=2
18x8.5 +25 Front
18x10 +25 Rear
#4707
I got 19x8.5 +30 19x10 +38 Linea corse LC818's and I previously ran 225/35/19 and 255/35/19 and I had a bubble in one of the tires in the front so I want to steer away from that stretching direction since its a daily. Got fenders rolled in the rear. Whats the most meat I can run on these wheels?? Please input asap I want to order next week!
#4708
19x8.5 +30 with 235-35-19 I am running. My car is 1.5 inches lowerd on BC Racing. All good. Barely rubs. And when it rubs, it is only on the fender linder. Very minor. No fender mod besides heat gun fender liner.
#4709
#4710
URGENT PLEASE HELP QUICK
About to buy these from someone, just need to know if it's workable..i dont mind rubbing, but wheels has to fit
19x9 +20mm offset
19x10 +30mm offset
2008 IS350 on Eibach Pro Kit
I'm thinking the rear should be OK, but the front, im not too sure?
19x9 +20mm offset
19x10 +30mm offset
