Will those wheels fit? START HERE.
#4711
#4712
#4713
https://www.clublexus.com/forums/is-...ano-black.html
#4714
not an aftermarket wheel question but is it possible to upsize the OEM tire size on the stock wheels. I know on a lot of other cars you can do this. Like on TSXs you can go from 215/50/17 to 225/45/17 on the same OEM wheels.
For instance maybe upsizing from 225/35 255/40 to 235/35 265/35 on the 2IS
#4715
front 19x9 with 235/35
rear 19x10.5 with 275/30
what kind of offset should i be doing for a flush look?
considering either forgestar f14 custom offset or wedssport sa-55m +38 front +24 rear
other info:
25" fender-ground all around (awd on coils)
natural camber (possible -1 to -1.5 after alignment) ... MIGHT consider camber arms front and rear
no fender mods but willing to roll
other info:
#4716
other info:
other info:
You should be fine with that amount of camber. I have -1.5 up front and -2.5 in the rear and have not had tire wear issues. To be flush, you will need to roll the fenders and possibly relocate the front fender tabs. No pulling is necessary.
#4717
With all else being equal I doubt you will be able to tell any difference with either sized tire set, 10mm width isn't going to change much.
#4718
+28-+30 up front and ~+25 in the rear will be "flush." Ive noticed that a lot of people consider hellaflush to be the same as flush, so Im providing you with the real "flush" offsets.
Yes I want an actual flush no poked/hellaflush/madcamber/etc.
Even rear need relocating tab?
#4719
So I am very uneducated when it comes to wheel fitment - have never had a set of aftermarket wheels before and definitely do not know enough about tire sizes/fitment and offsets to feel confident in purchasing wheels without some insight from the pros.
I am considering the new Ground Force GF07 Wheels
![](http://www.dragtimes.com/images-classifieds-large/18-GROUND-FORCE-GF07-CONCAVE-SILVER-WHEELS-FITS-HO-for-sale_200950434621.jpg)
These wheels are brand new and will be custom offsets. The manufacturer recommended the following:
19x9.5 + 35
19x10.5 +40
Question:
If these recommended specs are OK - what size tires would you recommend?
Concerns:
From what I have seen, 9.5/10.5 seems a bit too wide/aggressive for no rubbing issues? Should I consider 19x9/10 or some other size?
Info on Car/Fender Work:
I am currently lowered on Megan EZ's at approximately 24.5" from ground to fender.
I don't mind rolling my fenders, but I do not want to run an aggressive stretch or pull/cut anything to make these wheels work. My 2IS is my daily driven vehicle and the roads around here are not too great.
I appreciate any advice... thanks in advance!
-Zach
19x9.5 + 35
19x10.5 +40
Question:
Concerns:
-Zach
#4720
I currently have some work vskf wheels that I plan on soon installing.. They are 19x9 +26 in the front and 19x10 +21 in the rear. I plan on installing 225/35 in the front and 255/35 in the back
Will I run into any issues at stock height?
I plan on installing ez Megan's soon
Thank for the help in advance
#4725
They will fit sinec you are lowered already, all you would need to do is run a 245/35/19 front and a 265/35 rear which is a slight stretch but nothing crazy at all. it would be a flush fitment
19x9.5 + 35
19x10.5 +40
Question:
Concerns:
-Zach
19x9.5 + 35
19x10.5 +40
Question:
Concerns:
-Zach
