Will those wheels fit? START HERE.
#4833
I am wondering if these will fit and if so what tires?
2014 IS350 AWD
Bolt Pattern: 5x114.3
Rim Width: 8.5 & 9.5
Hub Bore: 35 & 22
Rim Diameter: 19
Rim Structure: One Piece
Offset: 25
Rim Brand: VMR
Thank you!
2014 IS350 AWD
Hub Bore: 35 & 22
Rim Diameter: 19
Offset: 25
Rim Brand: VMR
Thank you!
#4834
Hey friends, long time Nissan guy, just picked up an IS350. Looking to maybe try and put my 18x9.5 +15 all around RPF1's from my 240 on the Lexus. Looks like that's a pretty low offset judging from the other setups I've been looking at. Anyone ran these sizes or have any pics? Thanks Fellas
#4835
^ That is a pretty low offset but it will fit, look here:
https://www.clublexus.com/forums/whe...ort-tires.html
I don't know what fender mods sr20mofo did to get these to fit, so I suppose whether or not you agree that they fit depends on what mods you are willing to do and what kind of rubbing you are willing to live with.
#4837
Hello CL members...I need your help... I have a 2006 is350. I'm trying to fix her up a little. I'm getting megan ez street coilovers, plan to drop about 1.5 inch all around. Here is my question...will these wheels ( concept one CS 20 )and tires will fit my car without rubbing or fender rolling? FRONT 20X9 40ET 235/30/20 REAR 20X10.5 45ET 275/30/20 I did some research for a whole week now, it looks like this set up gonna works for me, but I'm not 100% sure. I like to hear from you guys first before I purchase it. Thank you all....
Here's a pic of how my car looked like when I had barley put the rims on and with the 275 tire in the back
![Will those wheels fit? START HERE.-image-2428580215.jpg](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/312253d1461366886t-will-those-wheels-fit-start-here-image-2428580215.jpg)
![Will those wheels fit? START HERE.-image-3054701017.jpg](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/312252d1461366886t-will-those-wheels-fit-start-here-image-3054701017.jpg)
#4838
Hello I'm new to this forum and I have a question . I have a 2008 lexus es 350 and I'm installing the brabus monoblock III tires rear 255 /35 /20, front 245 /35/ 20 the wheels have the correct centric ring with wobble nuts. my question is do I need spacers?
Thanks in advance I'll appreciate your help
#4839
#4841
I'm interested in these:
http://www.discountedwheelwarehouse....%2Es&pID=48763
Will they fit a 2010 IS250 RWD. Some wheel packages have staggered wheels. What are the benefits to staggered wheels and different offsets?
#4842
What do you think?
#4843
I have an '06 350 and I want a square setup for the track. I'm at stock height right now, but I'll probably end up with new coilovers sometime this year. I'm not planning on going low, no more than an inch drop I'd say. I'd like18x8.5 wheels, and these tires. Should I be good with 235/40/18? If I can fit a 245, that would be nice. I don't want to do any pulling an rolling, so if I need to go smaller I will.
Am I in the right ballpark on sizes? What kind of offset do I need to look at for this?
#4844
^ For a track setup I would suggest considering 17" wheels.
Personally I'd go with an RE-11, or a Direzza ZII over the RS-3, but that is just me; any tire in that class will outgrip 99% of the rubber on the road.
245s will fit, quoting someone more knowledgable than myself:
Offsets close to stock should work fine with 245 width tires; Jeff is running stock 17" wheels.
