Will those wheels fit? START HERE.
#4921
kind of desperate for answers so ill try here also hahaha. curious if I run varrstoen es1 19x9.5+22F 19x11+25R,
I know ill have to roll fenders but any suggestions on what tires size and etc... if i dont go with them I might get the es7's same size and offset... or would it be better off running a square set up 19X9.5 +22F and +30R. Thanks
#4923
Looking to buy the TSW Sochi wheels in 18x8.5 front with +30 offset. 18x9.5 rear with +30 offset. Question is will the fronts fit over calipers on myIS350. When I go to TSW website and enter my vehicle info it does not pull up my car?? These wheels have slight concave but not aggressive. I don't want to use spacers. Any way to find out if these will fit on my car??
#4924
Hi CL,
I am wanting to get some Work VS-xx and be lowered on BCR coils, probably not slammed. I'm also looking to not do any fender mods. Specs are here.
19x8.5 5x114.3 +41
19x9.5 5x114.3 +42
What tires do you recommend and will it work? thanks
19x8.5 5x114.3 +41
19x9.5 5x114.3 +42
#4925
Looking to get a set of wheels:
F: 18x8 +30
R: 18x9 +25
Stock height and stock fenders. Might lower a bit later.
Would this be flush with the fenders? I did some calculations and it seems to be pretty close but it would be great to get some feedback from you guys.
Thanks
F: 18x8 +30
R: 18x9 +25
Thanks
#4927
F: 18x8 +30
R: 18x9 +25
Thanks
F: 18x8 +30
R: 18x9 +25
Thanks
I wanna say 225/35 and 265/30, but with that front offset you may need to go with a more aggressive stretch.
#4928
Ok got wheels in my living room need to buy tires..
Xxr530
18x8.75 20mm front
18x9.75 20mm rear
Currently lowered on Megan coilovers.running stock 17 is250 awd wheels with 2finger gap all around.what size tires would I need for a clean flush look and what kind of rolling and pulling will be needed.not looking for a big poke,the closer to flush the better.and yes my car is awd
Xxr530
18x8.75 20mm front
18x9.75 20mm rear
#4933
Hey everyone,
So I plan on getting some custom built rims as I have been searching for some similar specs for awhile now and can't be found.
I plan on building some VSxx's to 19x9.5 +30, 19x10.5 +30
I figured that will give me a flush look + a little aggressiveness ?
I'm on Megans EZs at the moment, and probably only planning on rolling my fenders only with stock camber.
What do you guys think? should I go a little lower on the offsets? This is my DD.
I'm trying to get a flush look with a tiny tiny aggressive look.
Thanks in advance for any input!
#4934
Hi everyone,
Thinking of getting the below rims. I'm pretty certain they'll fit & will be a bit aggressive.
08 IS250 RWD (lowered on Tein S-tech so there is some negative camber)
F 19x8.5 +22 (225/40/19)
R 19x9.5 +22 (255/35/19)
Does this look weird?
Would any guard rolling/fender work be required?
Cheers,
Jay
Cheers,
Jay
#4935
Hey Guy,
I want to upgrade to this new wheels from Zedd SL5. Wondering if you guy can help me with the fitment. I am currently low on Megan coilover with fender already roll. Need help on tires size. The wheel spec are 18x9.5 with +12 and +22 for the front and back are 18x10.5 with +22 and +15.
Which offset would be the best for the Is250 and tires ? Would I need to get an after market camber kit or I should be fine with just the stock. Thanks
