Will those wheels fit? START HERE.
Old 03-23-15, 07:06 PM
  #5146
VTsuckah
VTsuckah's Avatar
Originally Posted by Skathious
19x10.5 +33 all around on a 2is?? What kind of problems might I run into?
The fronts will require A LOT of work to make fit. The rear is doable with a fend roll and a slight pull. Camber and stretched tires will be your friend.
Old 03-25-15, 12:06 PM
  #5147
Den350
Den350's Avatar
Default Dropped on BC coils. .
Sorry to post this question but I'm going nuts trying to find an answer!! Lol....any opinions or answers as to the best setup for a 19 inch wheel...Car will be lowered with hopefully no gap... (not tucked) . What is the best setup for least amount of problems...please help guys..Thank you
Old 03-29-15, 01:24 PM
  #5148
Nchang96
Nchang96's Avatar
Originally Posted by Alwaysgolf
you're probably going to have to at least trim your fenders
What do you mean by that? you mean the fender liner?
Old 03-29-15, 01:33 PM
  #5149
LP817
LP817's Avatar
Probably means shaving the fender.
Old 04-01-15, 03:07 PM
  #5150
2IS35O
2IS35O's Avatar
Hey guys need some help! I picked up some vossen cv1s for a steal and need to know if I can make them work on my 08 is350
Front : 20x9 + 20 offset
Rear: 20x10.5 + 25 offset
I'm on stock ride height
Thanks for your help!
Old 04-01-15, 07:30 PM
  #5151
pandaevoz
pandaevoz's Avatar
just picked up a set of wheels 19x8.5 +35 and 19x9.5 +40 offset. what is the recommended tire size i should get. it's for the is350 lowered on coilovers about 1.5-2.0.
thanks in advance
Old 04-01-15, 10:23 PM
  #5152
TLRD
TLRD's Avatar
Default 10/11
Can someone running a 19x10/11 setup PM me? Need some help with fitment.
Old 04-01-15, 10:29 PM
  #5153
smokyis350
smokyis350's Avatar
20x9 +31
20x10 +44
What tires size would I need?
Old 04-06-15, 11:22 AM
  #5154
Alwaysgolf
Alwaysgolf's Avatar
Get your fenders rolled or trimmed . Slap some 225/35r20 for the front and 235/35 or 245/35r20 for the rear and they'll clear fine .
Remember that tire stretching is your friend !
Old 04-06-15, 11:24 AM
  #5155
Alwaysgolf
Alwaysgolf's Avatar
thanks in advance
If you want a low profile low/ sorta stretch look , get 225/35r19 and 235/35r19 .
Old 04-08-15, 01:49 PM
  #5156
kingap
kingap's Avatar
What is the most aggressive setup I can run on my 2007 IS250 RWD without having to pull/roll/camber? I will be lowered on EIbach Pro Kit springs and i'm looking for 19" wheels.
Looking for a set of LM Reps, thinking of going the Varrstoen ES1 route.
Old 04-09-15, 01:24 PM
  #5157
meegunz
meegunz's Avatar
19x8.5 +45 all around on a 2is. Will these fit?
Also, the wheels are 5x112. Would all I need are hubcentric rings and wobble lug nuts?
Thanks in advance!
Old 04-09-15, 05:23 PM
  #5158
srt1
srt1's Avatar
Dang there's so many questions and so many replies on this thread. Hoping you guys can hook me up and sugg a few things.
Currently; HRE 19x9 +24 offset (front)
19x10.5 +31 offset(rear)
sitting on coilovers
I'm wanting to, future, go a lil more aggressive in front and rear. I'm not too informed bout off sets so I don't know what to get.
Old 04-10-15, 11:41 PM
  #5159
user 692802
user 692802's Avatar
Looking at some wheels online ,
20x9 ET 25 fronts
20x10.5 ET 30 rears
'08 is350 H&R springs
Thoughts? Thanks
Old 04-12-15, 12:31 AM
  #5160
miketranis
miketranis's Avatar
you will need some work in the rear if you dont want to rub
Quick Reply: Will those wheels fit? START HERE.
