Will those wheels fit? START HERE.
#5176
[QUOTE=dbuch07;9001644]searched through multiple different pages found no luck. I might of missed this but oh well. I am looking at purchasing 19x8.5 wheels, what offset range should I look to stay in, typically not great with expertise on wheel fitment? Also what tire size would you recommend as I am lowered about 1.75" or so, I would not like to roll my fenders if possible at all.]
can anybody shed some light on this please for my is350 awd?
#5177
Being that you're AWD (like me) its actually not the best idea to run a staggered setup (bigger in the back) as it isn't good for your drivetrain. Its always safe to have a square setup, same tire size and rim size all around.
Some people have done the staggered setups on their AWD's by calculating sizes so its the same rolling diameter front and back, but in the long run, a lot of the feedback has come down to regretting doing it in the first place. It can be done, but you run the risk of putting extra/premature wear on your vehicle.
You can run an aggressive setup by all means, but just keep a square setup if possible. (e.x. 225/40/18 Front and Rear, same rims all around)
Just my $0.02
Just my $0.02
If I were to run that setup would it fit without rubbing? I prefer not to roll/pull the fenders either unless I HAVE to.
#5178
Hi there fellow IS owners
I have a stock dark grey IS250 RWD with stock 17' rims. I decided to leave winter tires on those rims and get some nice other ones for summer.
At the end I decided to go with Japan Racing JR11's
The options are:
17X8,25 ET35 5X112/114,3
or
18X8,5 ET40 5X112/114
18X8,5 ET30 5X114/120
I currently have very little used good 17' summer tires (225/45), thats why Im considering that 17' option.
The question is:
should I go with 17's with ET35 (i like that deeper look), or should I go with 18' ET40 (I guess ET30 won't fit)?
Thanks for any advice!
The options are:
or
The question is:
#5181
The options are:
or
The question is:
The options are:
or
The question is:
Yes.
#5183
Hey how's it going everyone. New member but I've been reading a lot of threads.
My question is what tire size should I get? Will I rub?
1) 225/30/20
2) 235/30/20
3) 225/35/20
4) 235/35/20
I'm getting Vossen CVT wheels. 20x8.5 offset 38 all around. And I will be lowered on H&R sport springs. Thanks in advance. Pictures with this set up or similar would be nice.
1) 225/30/20
2) 235/30/20
3) 225/35/20
4) 235/35/20
#5184
2006 IS350 w/ RC-F Wheels Question
Hello, I'm new to CL and I have been reading through many, many pages of the "Will those wheels fit? START HERE." sticky (I'm up to page 218). I'm looking for info on what I need to do to make the new RC-F wheels that I bought fit on my 2006 IS350.
RC-F wheels specs: 19×9.0 offset 50 & 19×10 offset 41
smokyIS350 was a big help, many thanks smoky. He suggested using 235/35/19 and 275/30/19 sized tires.
He said the rear tires/wheels will be fine with this set up, no rubbing-no mods needed.
I am still unclear on what I need to do to make the front set up work. I would rather not stretch my tires if at all possible.
Here's what I have gathered:
I need at least +38 offset, which means I will need to get 12mm spacers. ( looking at these: Ichiba V1 Wheel Spacers 12MM)
Could anyone chime in on the proper front set up that would require minimal tire stretch and proper spacer size? Thank you very much for your help.
#5186
i have a is250 awd. i am looking for wheels but not sure what my ranges are. i know that i want 18". Either 8.5 or 9.0 as the width. with 8.5" what are my ranges of offset? and with the 9" what are my ranges of offset.
#5187
in terms of wheel specs, I would not run any spacers unless you plan on getting fender work done for more clearance - especially with the suggested tire specs. the OEM RC-F wheel specs will stick out a little over 1/4" up front and almost 1 1/8" in the rear. with your proposed wheel/tire specs, the rear may need work, but IMO get the wheels and tires on the car first and then see if it's absolutely necessary.
in regards to spacers, the only reason you should ever run spacers is because you need to clear brake calipers. Should you decide to run spacers, you'll definitely need fender work.
btw, thanks for the good words, but it's nothing I take credit for.
#5188
18x8 35mm (F), 18x9.5 45mm (R)
I currently got 18" staggered OEM wheels on my '06 IS350. Looking to get flushed set up. Not looking for anything poking out. I much would rather have the rear somewhat flushed. So I found a set of TSWs 18x8 35mm (F), 18x9.5 45mm (R). How will this set up be like?
#5190
Please help - Mountain Run / Track / Autox Wheel Setup -
Hey guys, I've been research for dayssss and I can't seem to find much on these wheels. Any help would be absolutely splendid please.
A Few things:
1. Running on Megan Coils - Tucking about 1/4 of tire all the way around (willing to compromise and increase ride height IF needed to but would like to avoid).
2. Already bought 225/40 & 255/40 tires sizes - can trade in for other tire sizes but would have to pay on top - trying to avoid
3. I would like a decently flush setup but nothing too agressive
4. I go on mountain runs A LOT, tend to do some autox, and track visits so running super stretch tires are a no-no for me. Most i will be comfortable stretching is a 255 on a 10". Would like to eventually run a 245/35 or 255/35 in the front and a 265/35 or 275/35 in the rear
5. I have already modified my fenders. Rolled flat and 2mm pull in the front (tabs not yet relocated), and Rolled flat with maybe a 1mm pull in the rear (willing to pull more if necessary).
6. Currently running on stock 18's X-package rims (F - 18x8 +20 / R - 18x9.5 +20 (both with spacers) wrapped in 225/40 and 255/40
7. I plan to get RPF1's which I have heard may have a slight problem with clearing the front caliper without a spacer.
7. These are the choices I am working with that need confirmation (Please modify if you feel that they are absolutely necessary)
Other options for wheels are as follows:
18x8.5 +30
18x9 +35
18x9.5 +38 or 45
18x10 +38
This is the setup I plan on doing:
F - 18x9 +35
R - 18x10 +38
Goals:
Run a 9 in the front because the 8.5's are convex and look like ****)
Eliminate Spacers Fully (will run if absolutely necessary) - Please tell me what size
Obtain a decently flush look without compromising ride height - I would like to stay lowered
Eliminate rubbing - i don't mind a little rubbing as i already rub a ton in the front (on fender liner)
Please help. I am willing to sacrifice whatever small thing i need to from looks so I can perform and handle better. The more input the merrier! And Thanks SO much in advance for the help.
This was my previous car btw when I was into heavy fitment (not a fool noob & I do research). Now going to performance
Some of you may say that I am wanting the best of both worlds and can't have it. Well, instead of flaming me, try and help out?
A Few things:
18x8.5 +30
18x9 +35
18x9.5 +38 or 45
18x10 +38
F - 18x9 +35
R - 18x10 +38
Goals:
