Will those wheels fit? START HERE.
#5221
I am currently looking to buy some 18" WORK VS-XX for my lexus is350 rwd 2007
The specs are :
F: 18x8 +38
R: 18x9 +50
I was wondering if the fronts will be able to clear the bbk?
Also the wheels comes with 4 brand new 215/40/18 tires. Is it okay to use these tires instead of the recommended 255/40/18 for the rears?
Thank you guys
The specs are :
F: 18x8 +38
R: 18x9 +50
Thank you guys
#5223
Hey guys! I need some help. I've got a set of cosmis xt-005r's .... 18x10 +20
Will these clear the front? I'm on road magnets, 2" drop all the way around. Tires 245/40 front 265/40 rear.
Coilovers will come down the road. My car is under construction so I am just looking to work with this set up... All input & advice will be appreciated!
#5224
i was wondering if 19x9.5 all around front +35 rear +20 work on 06is350? will i need to roll my fenders? i know i need spacers on the front because it does not clear the caliper thanks guys! 235/35 tires
#5225
I've searched quite a bit through the thread, but just for clarification:
Without any modifications, and f-sport springs will this wheel and tire combo clear?
19x8.5 +30 F 225/35
19x9.5 +35 R 255/35
19x8.5 +30 F 225/35
19x9.5 +35 R 255/35
#5226
I "think" these will fit based on multiple searches. Just need a double check please. Looking to install these on 2010 IS350c awd. I don't want to modify anything.
Finish:**Hyper black face with polished lip
Rim Size:* *19 X 8.5" fronts *& *19 X 9.5" rears
Lip:*1.5" fronts / 2.5" rears
Bolt Pattern:* 5 X 114.3
Hub bore 73.1
Offset:* 35 mm fronts & 40 mm rears
Thanks
Hub bore 73.1
Thanks
#5227
What's up CL...I just purchased some workmeister S1s for my 06 250. I'm wanting to widen up the rears. I was thinking about using the 18x8.5 +37 up front and relipping the 18x8 +36 to a 9.5 or even 10?
QUESTIONs:
- will 18x8.5 +37 for the front be a flush fitment
- what's my best option for the rears going to a 9.5" or 10" wide for flush fitment (slight camber okay but don't want to install camber kit if possible)
currently lowered almost 3" on megan LPs and both front and rear fenders are rolled. Your input is greatly appreciated!
QUESTIONs:
#5228
QUESTIONs:
QUESTIONs:
![Name: 133387_4470288631225_579381473_o.jpg
Size: 111.9 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/448104d1501528246-will-those-wheels-fit-start-here-133387_4470288631225_579381473_o.jpg)
![Name: IMG_4201.jpg
Size: 97.5 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/448105d1501528246-will-those-wheels-fit-start-here-img_4201.jpg)
#5229
just curious with that current set up how big of a spacer do you think you would need to run to get a flush fitment?
#5230
thanks for the response and reference photo! this helps out a lot, especially that rolling shot. Looks like i'll be running some sort of spacer in the front but will definitely widen up the rear. If I converted my 18x8 +36 to a 18x10.5 (2.5" wider outer lip) do you think that would give me a more flush fitment?
#5231
hello everybody
buy new rims without tires
18x8 +25
wich tyre can i used without rubbing in the rear?
245/40/18 or 255/40/18
in the front i have 8x18+37 this is not the problem
IS250 is eibach lowered 1,4 inch at the rear anyone try this?
lexus IS250 2007
greetz from a european trucker
18x8 +25
lexus IS250 2007
#5232
I need some expert help me out with the Wheel and tires please.
iS350 LOWER ON Megan LP
Rolled Front and rear fender (relocation bumper tab is done as well)
currently running on
20 x 8.5 +30 front 235/30/20
20 x 10 +32 rear 265/30/20
Could
20 x 8.5 + 15 front wheel
20 x 10.5 + 20 Rear
fit on IS 350? What size of tire should i use?
Any help is very very appreciate. Would love to see some pix as well.
Thanks!
Could
20 x 10.5 + 20 Rear
Thanks!
#5234
Hi,
I was thinking of buying the following setup;
18 x 8.5 offset +33 on 225/45/18 in front
18 x 9.5 offset +22 on 255/45/18 in the back
will the rear tire rub ? Fenders are already rolled. Or should I go with 245-235 in the back ?
Thanks !
Thanks !
#5235
what up CL, ive been reading alot post and cant to find the same set up i was planning,
i got 18x9.5 +22 all around with h&r springs.
thinking putting 225/45/18 in front and 245/40/18 rear or 235/40/18.
do i have to roll or shave linings?
im trying to avoid any fender work/mod, and keep a good quality ride.
if anyone can suggest a best tire sz for 18x9.5 +22 prefer beefy tires than stretched
thanks appreciated
thanks appreciated
