Will those wheels fit? START HERE.
#5236
thanks for the response and reference photo! this helps out a lot, especially that rolling shot. Looks like i'll be running some sort of spacer in the front but will definitely widen up the rear. If I converted my 18x8 +36 to a 18x10.5 (2.5" wider outer lip) do you think that would give me a more flush fitment?
just curious with that current set up how big of a spacer do you think you would need to run to get a flush fitment?
WHEELS: Work meister S1 3p 18x8.5 +30 (2.5" outer lip) / 18x9.5 +24 (3.5" outer lip) (no spacers required)
TIRES: front 225/40/18 rear 245/40/18
DROP: 2 inches? on Megan LPs (would like to drop another 1/2")
FITMENT: 1/4"/ less than 1/2" sunk in front/ flush at rear (rolled rear fenders are a must unless you stretch tires?)
ISSUES: with my current drop only issues are going over pot holes and some steep driveways. tires rub inside fender liners sometimes but not the bumper tabs. No issues on u-turns
fitment looks proper however I should have went with a smaller profile tire.
QUESTION: would running a 225/35/18 and 245/35/18 be a noticeable difference or should I run a 30 profile?
#5237
Wheel and fitment gurus, please help me out!
I plan on picking up some SSR Vienna Kreis later today and I want to make sure i can fit these with no issues.
Front: 19x9+26
Rear: 19x10+24
Im lowered on BC Racing coils with no finger gap on stock 18's my alignment is dialed in, will I have to readjust alignment?
Front: 19x9+26
Rear: 19x10+24
#5238
Front: 19x9+26
Rear: 19x10+24
Front: 19x9+26
Rear: 19x10+24
I'm running similar fitment (slightly more aggressive) on my IS. 19x9 +21 19x10 +21. I needed to roll and slightly pull my fenders, but I have camber arms to straighten out my camber. If you have some camber then you should be fine with just a roll. Just remember you should relocate the front fender tabs.
#5239
Those are my friend's wheels lol.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
But I got the rears to fit nice with close to stock camber and a roll
#5240
I'm planning on buying some wheels with these specs: front19x8,5 +30 and rear19x10 +36. 225/35R19 and 245/35R19 (would like 255/30 or 265/30 rears). I'm lowered on H&R (about 1.35 inch). Will this fitt without rolling or rubbing? Thx in advance.
#5241
I am about to order a set of WORK Emotion CR 2 Piece Wheels. 5X114.3 (2) 18X9 with 38 offset and (2) 18X9.5 5X114.3 with 22 offset, these will be going on a 2009 is350 RWD, my car is dropped about 1.5-2". my front fenders had been rolled already, but I am not sure what tire to use?
will this set work on my car?
will they rub?
if any one can help, I will appreciate
will they rub?
#5243
will they rub?
if any one can help, I will appreciate![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
will they rub?
Anyone? Please
#5244
Most setups are 32 and 38 offset. Anyone knows if 30 and 36 will be problem?
#5245
Hello, I would like to purchase these STR06 rims fit my car? They look just like the CV3s without the 2000+ price tag, and I'm getting a good deal on them.
My car is RWD,
I'm looking at 20 X 9.5 offset of 35
And 20 X 10.5 offset of 40.
I'm aware I will need to do fender rolling, and maybe even a pull, but I have no issue with that.
My car is RWD,
#5248
I hope this isn't a repeat question as I couldn't find anything definitive about these specs. My issue is only with the front wheels.
I just bought a set of VIP Modular VRC13 19x10.5 +25 all around. The guy had them on his 2011 IS250 lowered on coilovers with everything else stock, and said he was able to clear them up front by stretching 225/35/19 tires.
My 2008 IS250 is bagged, with SPC balljoints up front maxed at -3 degrees, fenders rolled and bumper tab removed to fit my current 9.5 +15 stretching 215/35/19 up front.
Will I have any issues fitting the 10.5 with 225/35/19 in the front the way I'm set up right now? I'm only looking for full lock turns at drive height, and fender clearance when I air out.
#5249
Im on BCR coils, but also SPC camber, also maxed at -3 same size front tires and bumper tab moved
My fronts are 19x9+9 and I can go full lock with room to spare
#5250
Moment of truth on Feb 20th! I will keep the forum updated, with pictures of course.
Shout out to IG user tailored_media for selling me the wheels. For previews of what the wheels look like on a 2is, I suggest to go look through his pictures. I would post them here myself but that just doesn't give him enough credit.
