Will those wheels fit? START HERE.
Old 05-26-16, 09:23 PM
  #5281
eric08
eric08's Avatar
Default aftermarket rims is350
Can i fit these rims and tires on a 2008 is350 without much modification?
Fronts:
18x8.5
Et +30
235/40/18 tires
Rears:
18x9.5
Et +15
255/35/18
Old 06-02-16, 10:50 AM
  #5282
IamLexus
IamLexus's Avatar
Will these fit on my Stock 2007 AWD?
http://motivwheels.com/wheel_item/modena-409b/
Wheel Size: 18x8 Bolt pattern: 5x4.50/5x120 Offset:42mm
Squared Set-up with recommend tire size?
Old 06-12-16, 05:16 PM
  #5283
ortymd34
ortymd34's Avatar
Default Curious about tires and wheels
I just bought a 2006 is350 and i really want to get the audi rs3/rs5 replica wheels. the specs on them are 19x8.5 +38 66.6 hub. i am wondering if they will fit in the front and rear since i am going to need the bolt pattern adapters from 5x112 to 5x114.3 which will be an additional inch. and also what would be the recommended tires to run on these wheels to make this setup fit on stock height.
http://www.rtxwheels.com/en/wheels/r...chined?cid=677
Old 06-13-16, 01:42 PM
  #5284
Silver09IS
Silver09IS's Avatar
Those won't fit cause our bolt patters are 5x114.3. I recommend a squared set up cause you're AWD
Old 06-13-16, 01:46 PM
  #5285
Silver09IS
Silver09IS's Avatar
They will fit because the rims are +38 offset you should be fine. Run stock tires I think thats 235/40/18 and for the rears 255/40/18 unless they're not staggered like ours
Old 06-14-16, 07:58 AM
  #5286
vicdog
vicdog's Avatar
Old 06-27-16, 04:33 AM
  #5287
Gratz81
Gratz81's Avatar
Wondering if a set of 19x8 +35 offset with 245/35/19 would fit all around. Have a 07 is350 stock height.
Old 06-28-16, 05:52 AM
  #5288
brazilero
brazilero's Avatar
Hi, guys
Whether I will be able to set such parameters to a stock is350 2006
Wheels Work Euroline Fe
Fronts: 18x8 Et+38 225/40/18 tires
Rears: 18x9 Et+42 245/40/18 tires
Old 07-21-16, 06:42 AM
  #5289
strikeraj
strikeraj's Avatar
I have seen people putting 350z track pack forged wheel on SC and LS on this forum
But will those work for an IS350?
Old 08-02-16, 05:27 PM
  #5290
ashlykov
ashlykov's Avatar
I have some MSR style 169 with 5x115 bolt pattern to fit. Can anyone help? Thanks!
Old 08-10-16, 10:31 AM
  #5291
knyg
knyg's Avatar
Default How will this fit? Any pictures?
Going to put on 19x8.5" +35 on all four soon. What tire size is good? (I'm thinking 245/35/19, also willing to go 235/35 but not lower). Also, how much can I drop my car? I have coils so I can adjust them if needed. Will these specs rub? I am also willing to remove fender liners and roll my fenders if needed.
Old 08-10-16, 10:34 AM
  #5292
knyg
knyg's Avatar
lexus IS are 5x114.3 for the bolt patterns. Your rims won't fit if you plan on putting it on just like that. You'll need some modifications, not even sure if it's possible. Sorry, you got the wrong bolt patterns.
Old 08-11-16, 10:32 AM
  #5293
LeXUsFeEVa
LeXUsFeEVa's Avatar
what's up CL...got new shoes and wondering about 35 profile tires for 18s. I previously had work meister S1 18x8.5 / 18x9.5 with 40pros but had rubbing issues (car lowered on coils). Was wondering if anyone had photo or opinions for 18s with 35 profile tires for 2nd gen IS250
New shoes: Leon Hardiritt Ordens 18x9 / 18x10 planning on running 225/35/18 and 245/35/18. Anyone advise/photos would be greatly appreciated.
Old 08-15-16, 01:33 PM
  #5294
HawkeyeIS
HawkeyeIS's Avatar
Looking at some Niche Misano wheels for my 2011 IS250 AWD and trying to decide if I should go with 19x9.5 et +35 vs 19x8.5 et +35. Will the 9.5 width fit on the front without issue? Will they stick out past the fender? I'm at stock height, so I think I'll be fine with tire clearance no matter what I run, just want to make sure I don't stick out past the fenders too much and that I don't hit components inside the wheel well due to being too wide.
Thanks
Old 08-15-16, 01:40 PM
  #5295
eric08
eric08's Avatar
Thanks
You mean the 8.5 in the front right? The 9.5 wont fit the front but will fit the rear. Im running the same set up just with a 42 offset and its very flush just be careful with tire size
Quick Reply: Will those wheels fit? START HERE.
