Will those wheels fit? START HERE.
Old 03-13-17, 01:03 PM
  #5341
E46CT
E46CT's Avatar
Received 2,205 Likes on 1,652 Posts
those look like as wide as you can go! right to the limit! =)
Old 03-21-17, 09:15 AM
  #5342
LeXUsFeEVa
LeXUsFeEVa's Avatar
Default Leon Hardiritt Ordens 18" re-build...IS gurus HELP please!
What's up CL...so I've had a set of 18" ordens sitting around in my garage and I've decided to slap them on my 06 IS250 (looking to build as close to correct fitment as possible). I currently have 6.5" and 7.5" inner barrels and multiple lips (2) pairs of 2" lips/ pair of 2.5" lips/ pair of 3.5" lips. Ideally I would like to be able to swap stock wheels and tires with these new Ordens without having to re-adjust camber, ride height etc. Faces/inners and outers are all at the shop currently about to be built to:
18x8.5 +18 (High disk 6.5" inner / 2" lip) : with 225/35/18 tires front
18x9.5 +35 (Low disk 7" inner / 2.5" lip) : with 245/35/18 tires rear
I'm currently riding pretty low on Megan LPs with stock wheels and tires and rear fenders rolled. QUESTION is the above fitment decent without any fender mods (don't mind rolling if needed) or should I change my build to:
FRONT: 18x9 +23 (High disk 7" inner / 2" lip) ......TEST fit proved lip to fender ratio super flush due to high disk (possibly need to roll front fenders)
REAR: 18x9 +29 (low disk 6.5" inner / 2.5" lip)
TIRES: 225/35 AND 245/35
OR
FRONT: 18x8.5 +35 (Low disk 6.5" inner / 2" lip) will low disk in front clear front IS250 calipers?
REAR: 18x9.5 + 18 (High disk 7" inner / 2.5" lip) Is it awkward to run high disk in the rears for IS250?
OR
REAR: 18x9 +24 (high disk 7" inner / 2" lip)
If i'm going to change up the build I need to make a decision in the next couple of days! GURUs please help!
Attached Thumbnails Will those wheels fit?  START HERE.-front.jpg   Will those wheels fit?  START HERE.-rear-2.jpg
Old 03-21-17, 11:28 AM
  #5343
cuongiee
cuongiee's Avatar
Hi CL,
Just wondering if I would have to do any fender work with this set up.
I'm on coils.
Front: 18x8.5 +30 -- 225/35/18
Rear: 18x9.5 +35 -- 265/35/18
Second option
Front: 18x9.5 +35 -- 245/35/18
Does anyone have pics of this set up.. I really wanna pull the trigger on these wheels.
Old 03-21-17, 01:41 PM
  #5344
LeXUsFeEVa
LeXUsFeEVa's Avatar
Default will Low disk ordens clear IS250 front calipers
OR
OR
So after doing some calculations and comparing possible set-up to when I had work mesiters on 18x8.5 +29 /18x9 +23 (which sat almost perfect with stock 40 pro tires) I believe my best option for rebuilding these ordens would be:
I know having 2" lips will be pretty weak but having 2" lips front and back for consistency should make it look more OEM? Anyway the real question is will Low disk ordens clear an IS250 front caliper?
Old 03-21-17, 03:20 PM
  #5345
02lexi
02lexi's Avatar
So I am terrible at determining if wheels will fit so I will just ask here. Car is lowered with rolled rear fenders
Front 18x8.5 +30 245/35/18
rear 18x9.5 +35 275/35/18
Old 03-22-17, 07:09 AM
  #5346
cuongiee
cuongiee's Avatar
Hi, we have a similar setup we want to achieve. I posted this 2 posts up. lol what wheels are you getting?
Old 03-22-17, 08:03 AM
  #5347
02lexi
02lexi's Avatar
i am going to run esr wheels
Old 03-23-17, 11:15 AM
  #5348
cuongiee
cuongiee's Avatar
lmao me too.... the sr02.. xD gunna get the all gold ones.
Old 03-23-17, 11:46 AM
  #5349
02lexi
02lexi's Avatar
Thats funny because I was debating on those or the sr1. I went with the sr1 in gold lol
Old 03-27-17, 01:17 PM
  #5350
Mrsharza
Mrsharza's Avatar
Default Please Help!!
hi, i'm new on here, please help!!!!
i have 19x10 rims +24 offsets on a 07 is250 rwd...
what's the widest tires i can put on?
i would like to keep it as flush as possible without any crazy camber adjustments... would consider rolling the fenders.
THANKS!!!!
Old 03-27-17, 01:32 PM
  #5351
5gears-IS
Great Deal Guru
5gears-IS's Avatar
Default Staggered Tires Fitment help
Hi Guys,
Hope someone can help me choose the correct size of tires for my following wheels:
2006 Lexus IS model: 350
Wheel Make & Model: Miro 111
Wheel Size (diameter and width): 19 x 8.5 F & 19 x 9.5 R
Wheel Offset Front: +35
Wheel Offset Rear: +40
Tire Size Front: 235/35/19??
Tire Size Rear: 275/30/19??
Car is lowered 1.5" springs
I dont want any major rubbing or any at all if possible
Any help will be appreciated.
Thanks in advance,
Tito
Old 03-30-17, 08:29 PM
  #5352
Tihkalsis
Tihkalsis's Avatar
Default Will these wheels fit
Old 03-30-17, 10:50 PM
  #5353
Jay21
Jay21's Avatar
Originally Posted by Tihkalsis
probably not, the IS rear end offset is different from the fronts so you cant run 4 wheels that are same size and offset
Old 03-31-17, 08:25 AM
  #5354
Idkjairo
Idkjairo's Avatar
Default Wheel fitment
Heey fellas. I'm thinking about buying these wheel but I'm worried that the offset on the wheels won't clear the brakes. Does anybody know if the offset will clear the brakes or would I need spacers?
Old 03-31-17, 08:48 AM
  #5355
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,305 Likes on 1,406 Posts
What brakes do you have (is your car a 250 or 350)?
What's the disk fitment of the wheels (high pad / high disk)? Need to know that more than the offset.
Quick Reply: Will those wheels fit? START HERE.
