Will those wheels fit? START HERE.
#5358
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
#5360
lmk how that goes. Our wheels are pretty much the same specs. I'm going to buy 235/35/19 for the front and 265/35/19 for the rear. I am thinking about BC coilovers as well in the future if I don't like how the car sits. For lowered cars, I see most ppl running thinner tires in the rear (265/30/19).
#5361
#5363
Hi CL,
Just wondering if I would have to do any fender work with this set up.
I'm on coils.
Front: 18x8.5 +30 -- 225/35/18
Rear: 18x9.5 +35 -- 265/35/18
Second option
Front: 18x9.5 +35 -- 245/35/18
Does anyone have pics of this set up.. I really wanna pull the trigger on these wheels.
I'm on coils.
Second option
Heres my setup:
18x8 +35 -- 225/40/18 (stock tires)
18x9 +30 --255/40/18 (stock tires)
The ride is perfect and it flushes really nice but I have to roll my rear fenders even because it rubs just a little when I drive on uneven roads but other than that its perfect and looks nice.
Posting pics:
cuongiee (01-25-18)
#5365
Post some pics after you finish! Good luck
#5368
Would M130 Targa rims fit my 2014 IS250 RWD 17" rims stock? The M130 Targa rims have the correct bolt pattern (5x114.3). The size is 17x8, the offset is 40 and the bore is 72.60 and the bore type is conical. Will these fit and will these work with OEM lugnuts?
#5369
The 2014 IS 250 RWD is staggered so you have to get bigger rims for the rear. Are you gona use your stock tires to put on the Targa rims? If so then make sure that you are rolling on 17's because I thought I had 17's on my 2011 IS 250 RWD but I was wrong, went to the shop and they said I had 18's on so my rim specs are 18x8 +35 in the front and 18x9 +30 in the rear(also lowered 2 inches). Lmk if this helps
#5370
I just checked they are all 17" wheels. Ideally I'd like to use the same tires. Will I have to get new lug nuts?
