Will those wheels fit? START HERE.
#5431
I am rubbing with my current setup with stock suspension 174k miles on the front shocks and about 70k miles on the rears (rears replaced around 86k miles at the dealership):
235/35/19 +35 F
265/35/19 +35 R
The front I am slightly rubbing on full lock turns. Need to hit the liner with a heat gun. The rears rub on big dips. I see the marks on the side walls of the rears from rubbing. Is this normal or are my rears shocks bad? I have already ordered my fender roller and I am going to roll my rear fenders soon.
235/35/19 +35 F
265/35/19 +35 R
#5432
My setup and NO rubbing.
235/35/19 +42 F (I recon 245/35 would fit)
265/30/19 +30 R
Lowered 1.1" F and 1.0" R. On big dips I hit rear but NO marks on tyres (very livable).
265/30/19 +30 R
#5433
235/35/19 +35 F
265/35/19 +35 R
235/35/19 +35 F
265/35/19 +35 R
#5436
Planning to get the following specs.
19x8.5 F +38 Tire 235/35
19x9.5 R +38 Tire 265/30 or 35
I know these specs will fit but wondering if I will be pretty flush or not? Not trying to poke or be hellaflush. Let me know!
Mild drop 1" all around.
Will I have the same issue as XSV with slight rubbing in the well?
#5437
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/800x600/4eee6f04_5b59_44af_aae0_b03ac9c11e7f_zpsyr6kulht_1d9224098c13fdaaa618eda5e6b6de4157383263.jpg)
#5439
Guy i was wondering if these wheels will fit on my 08 IS250 awd. Just need some wheel to get by for a few months.
18 x 7.5 5 x 114.3 bolt pattern (5 x 4.5)
Hub Bore 67.1
Offset 49.5
Thanks for your help in advance and sorry for posting here buy its looks like AWD thread is dead.
Hub Bore 67.1
Offset 49.5
#5440
Hub Bore 67.1
Offset 49.5
Hub Bore 67.1
Offset 49.5
xuserx04 (07-01-17)
#5443
May require a tiny bit of modification due to the negative offset but I'm not 100% certain, itll definitely be close. As for tire size Id do at least a 235/40 in the front just because 225 on a 9 inch rim isn't ideal, you may be able to fit a 245 as I've heard some people have done it without issue. As for the rear at least a 255.
#5445
Thanks everyone for the feedback. Is it bad to run a square setup on a RWD? (I'm new to the wheel/offset game) I was thinking to be safe and run 18x9 +30 all around since the rear might hit the fender/rub and I don't want to stretch tires for a 18x10 +25. Or will rolling my rear fenders fix this problem? Don't want to pull or shave.
@Idc if I go with 265/35 for the 18x10 +25 for the rear and I'm on Fsport springs (1inch drop) will the 35 series increase my wheel gap? Fsport drop has enough gap as is lol.
