Will those wheels fit? START HERE.
#5567
New to the forums. Picked up a 2006 is350, has stock 18s
lookig for Enkei ts9 in platinum gray, will be lowering Coilover about 1.5 inch or so
Front: 18x8, only available offset is 35 in gray. With 225 stock tires
Rear: 18x8.5 only available is 50 offset. Would be putting 255/40
question, no rubbing? Is the difference in offset too great that it would look funny? Maybe add spacer in the rear?
thanks
thanks
#5571
thanks
thanks
that 8.5 +50 in the rear is very close to OEM 18" wheel specs. you should be able to run mid- to low- 40's in the rear without fender mods if you're looking to run OEM-sized tires.
#5572
06 is350. im thinking of going with works emotion cr2p 20x10 +20 all around. what size tires and do i need to worry about disk type? im willing to do fender mods, as i will be bagged. also link to anyone with specs close to these will will be super appreciated!
#5574
been researching and looks like maybe A disk is fine. as far as tires, thinking about 255/35 all around. does that work? or would i need smaller in fronts?
#5576
Here is a thread with after wheels so you have an idea of the setups. https://www.clublexus.com/forums/is-2nd-gen-2006-2013/201509-aftermarket-wheel-owners-post-your-setup.html
gse21S (05-20-18)
#5578
its RWD. reason for square is so all the wheels have the concave and lip. if i go staggered, only the rears will be concaved but both front and rear will be lipped. but thanks for the info. ill keep looking.
#5579
for the fronts, you will need to roll and slightly pull your fenders, and shave your fender you might even need to shave them down afterwards for that extra bit of clearance. with all that, go with 225/30-20, nothing wider or taller.
for the rears, you will need to roll your fenders flat. the natural pull of fender rolling should be enough to create clearance. you can run a square tire set-up, but i'd at least go with a 235/30-20, maybe even a 245/30-20.
gse21S (05-20-18)
#5580
WORK Emotion M8R for stock 2006 is350
I want to get AG M310 wheels for 2006 IS350 (stock everything basically).
The specs are:
- [Front = 8.5x18 +35], [Inner clearance = 4 mm more, Outer position extended 16mm]
- [Rear = 9.5x18 +40], [Inner clearance = 14 mm less, Outer position extended 24mm]
My main concern is less inner clearance for the rear wheel - will this cause any problems or will it fit just fine?
The specs are:
