I want to get AG M310 wheels for 2006 IS350 (stock everything basically).
The specs are: - [Front = 8.5x18 +35], [Inner clearance = 4 mm more, Outer position extended 16mm]
- [Rear = 9.5x18 +40], [Inner clearance = 14 mm less, Outer position extended 24mm]
My main concern is less inner clearance for the rear wheel - will this cause any problems or will it fit just fine?
That'll be just fine. Should be pretty well flush. Just be careful with tire size. Thats all.
I have 225/40/R18 and 255/40/R18 for front and rear wheels and plan to use them for the M310s; do you see any major problems with its fit with the AG M310s? (Front: 8.5x18 +35, Rear: 9.5x18 +40)
No problems at all. Itll be very flush in both front and rear. Great setup
finally said **** it and just went with squared set up because i want to run these on my wrx too but
18x10 +15 all around. friggin love the poke fitment. that was my original goal! I rub hella up front with no fender mods. and rolled my rears and rub a **** ton on hard bumps. just need an aligment to max out OEM camber... i'll probably go with the megans camber arm kits all around eventually but for now I'll just run this set up until i go static jap low.
How would AG M310 19 inch wheels fit on a 2006 lexus is350 with stock everything? Would I have take any precautions with the extra inch?
Well it depends on a variety of factors, wheel width, offset, tire size. 19 inch rims have no trouble on our cars, but you will have to change the tire profile to maintain the rolling diameter and keep the speedometer relatively accurate. If you can give me more specifics on the wheels I certainly can help you further.
For a 07 Black AWD no drop. if Anyone find similar with a better price please let me know! I also would like to know if those will work with a Muteki 32906UN
It'd fit in the rear fine but not the front. You'd need to roll the fenders
if you're not looking to lower your ride height, these should work with the correctly-sized tires so you won't have to resort to fender modifications (roll/shave/pull).
To give you an idea of where they will sit, assuming you have AWD 2IS 17s' (17x8 +45), your proposed new wheels should extend a half inch farther toward the inside and a full inch farther outward toward the fender.
Assuming you'd like to keep a square (vs. staggered) wheel/tire combo, I'd recommend 245/35-18's to take advantage of the wider wheel width but at the same time offering enough clearance to avoid fender issues.
Reason: 245/35-18's...
Assuming you'd like to keep a square (vs. staggered) wheel/tire combo, I'd recommend 245/40-18's to take advantage of the wider wheel width but at the same time offering enough clearance to avoid fender issues.
Thanks that's what I'm planning to do! square for the awd do you know if they'll fit these lug nuts?
Thanks that's what I'm planning to do! square for the awd do you know if they'll fit these lug nuts? https://www.amazon.com/Muteki-32906U...muteki+32906un
I purchase them awhile back but my previous wheels didn't allow it.
The 2is uses 12 mm x 1.5 in. thread size lug nuts.
It looks like the lug nuts you linked are 12 mm x 1.5 in., so they should fit.
Also, in my previous response, I posted that you should run 245/40-18. I've corrected that to 245/35-18. the lower aspect ratio should not give more clearance but maintain a rolling diameter closer to that of OEM.
All due respect, this thread isn't the best place for you to find out what wheel looks the best on your 2IS. Maybe you might want to start your own thread and ask others? Or, decide for yourself what looks best on YOUR 2is instead of relying on the opinion of others? After all, it is YOUR money paying for YOUR wheels that'll be going on YOUR car.
Once you figure out what wheels you like, then come back in here to find out if they fit or not and how to make them fit if they fit.
Need some advise here. Will 18X9 ET35 and 18X9.5 ET22 fit on an IS250 RWD without camber kits and tab relocating? Planing to go stock tire sizes. 225/40/18 fronts and 255/40/18 rears.
