Will those wheels fit? START HERE.
#5641
I have a 2012 IS250 RWD. I am looking for a flush setup on stock suspension. I am looking to upsize to 19s. Which of these will give me that look?
19x8 +45mm
+38mm
19x8.5. +45mm
+38mm
19x9.5. +45mm
+38mm
+25mm
+15mm
i was thinking going with the 19x8 for the fronts and 19x8.5 for the rears. But I am unsure about the offsets.
19x8 +45mm
+38mm
19x8.5. +45mm
+38mm
19x9.5. +45mm
+38mm
+25mm
+15mm
#5642
Man, 378 pages is a lot to go through, so I feel this will be easier asked here this way. I have a 08 AWD IS250 and am looking to purchase new wheels, because the ones I have now have many little stress cracks.
Currently running a staggered setup,
18x8.5 +33 in the rear
18x8 +30 up front
I was wondering how 18x8.5 +35 all around would sit. rear I am not worried about. up front is what I am worried about rubbing and all. I have also been looking at a set that offer +35 which I would use for the rear and +25 up front.
I am lowered on BC racing coilovers.
Thank you!
18x8 +30 up front
Thank you!
#5643
Ran a search but didn't see anyone having this setup. Just wondering if it would work and what it would require. Trying to figure out how to get the most lip without too much fender mods. (only rolled fenders).
RWD
Front:
19x9.5 +35
225/35
Rear:
19x9.5 +22
255/35
RWD
Front:
19x9.5 +35
225/35
Rear:
19x9.5 +22
255/35
#5644
Search function isn't working as well as I'd hoped.
I've got an 08 IS350, not currently lowered at the moment, but will be soon.
Looking at
19 x 8.5 +30 F
19 x 9.5 + 35 R
Will they fit?
What tire sizes are recommended?
Looking at
19 x 8.5 +30 F
19 x 9.5 + 35 R
Will they fit?
#5645
235/35/19 or 245/35/19 front and 265/35/19 rear. You can also do 255/30/19 in the rear.
Check this thread, there might be some similar sizes with pics on the first page so you can get an idea:
https://www.clublexus.com/forums/is-...rs-thread.html
The following 2 users liked this post by NinjaSocks:
drtranis3 (09-05-19),
mthornto88 (06-19-20)
#5646
Does anyone know if the following spec fits on a 06 IS350?
ESR SR08 in:
18x9.5 +22 with 225/40R18 squared?
Will the wheels clear the brakes for an IS350? I'm also lowered on H&R springs with front fenders rolled.
ESR SR08 in:
#5649
I'm looking to get some new wheels for my 08 IS350 on stock suspension
Fronts:
18x8.5 40mm
Rears:
18x8.5 45mm
What size tires would fit? I wanna keep the same stock look on the tires like thin sidewall on front and a little thicker on the rears.
Fronts:
18x8.5 40mm
Rears:
18x8.5 45mm
#5650
i'm going to attempt a 19x8.5 +30 in the front and 19x9 +24 in the rear.
probably going with a 225/35/19 235/35/19 tire set up
rear camber arms and maybe just RSR downs for the moment.
#5651
pretty safe set up. Won’t really need camber arms unless you’re trying to zero out. Would maybe need a roll, at most.
#5652
these specs are pretty much stock specs, so run the same tire sizes on your stock wheels. 225/40 255/40
#5653
#5654
#5655
anyways i'm thinkin about going a little fatter on the tires. maybe a step up to 235/245. even though this is 2nd gen.. i'll keep yall updated hahahaha
