Will those wheels fit? START HERE.
Old 06-13-09, 02:53 PM
  #586
acefalcon2
acefalcon2's Avatar
it should be good... i'm doing 19x9.5 +35 with no rubbing but i am slightly stretching my tires
Old 06-19-09, 10:19 AM
  #587
adam`
adam`'s Avatar
Default 19x8 +45 with 225/35/19 in front?
Quick question, can I run 19x8 +45 offset wheels on the front of my IS350 with a 225/35/19 tire?
What would be the optimal tire size?
Rears are 19x9.5 +25 in 245/35/19
Old 06-19-09, 10:24 AM
  #588
as3.0cl
as3.0cl's Avatar
front would be fine but u can go more aggressinve on the front setup.
for the rears you wil need that stretch in your tire if your going that aggressive and wide of an tire.
if you give us an idea of your drop or what you are drped on more people can definitely help u out
Old 06-19-09, 10:31 AM
  #589
adam`
adam`'s Avatar
Minor drop on the F-Sport springs
I was originally going 19x8 +35 in front but found out the wheels are on back order and I'd have to wait like 6 weeks, the only alternative available is 19x8 +45 :/
Old 06-19-09, 10:42 AM
  #590
as3.0cl
as3.0cl's Avatar
no 8.5 fitment?
for me i like a wide tread on the rims, since your on F-sport you may be able to get away with 255 or 265 series tire with that offset.
i have +39 offset in the rear with a 19x9.5 wide rims running a 275/30. i like rubber on the ground. and i have no rubbing issues, i have less then a finger gad between the fender and tire sidewall.
Old 06-19-09, 11:47 AM
  #591
mdgrwl
mdgrwl's Avatar
If it helps, here's what I'm running.
225/35/19 19x8.5 - 23offset - FRONT (heat gunned)
245/35/19 19.9.5 - 27offset - REAR
Dropped on H&R Springs
I deff have room in the rear to go wider. I could either put a 5mm spacer to run a 22 offset, OR go with a bigger tire like a 255/35/19. But I can't do both if that gives you an idea of where I'm at.
Old 06-23-09, 10:32 AM
  #592
l3g3nd2
l3g3nd2's Avatar
Default another Rim fitment question for CL expertS!!
Hi Cl member! iam new to this site. I have a question about the fitment with an awd. I am thinking of buying the Works VS xx in 19 but iam not really sure which width and offset to go for. would 19X 9 all around with front 33 and rear +38 fit without needed to roll the fender? Would anyone please recommend a size for me please. I am trying to get the agressive look with flush. Thank yoU!
Old 06-28-09, 10:45 PM
  #593
DJKIBBLES
DJKIBBLES's Avatar
Default Rim offsets?
another offset question!! sorryyyy buttt will these fit without any modding and no drop for an lexus IS250 thanks in advance!
20x8.5 offset 38 tires = 245/35/20
20x10.5 offset 45 tires = 275/30/20
Old 06-29-09, 12:44 AM
  #594
t0e
t0e's Avatar
Front = no (get 235 or 225..)
Rear = Yes
Old 06-29-09, 01:17 AM
  #595
jonjon83
jonjon83's Avatar
y dont u get 20x9 in the front? since ur rear is pretty wide..
then have offset of 28-30 with 245/30/20 tires...
Old 06-29-09, 09:53 AM
  #596
DJKIBBLES
DJKIBBLES's Avatar
thanks t0e! so if i run smaller tires in the front should be ok?
thanks jon jon!! only reason im asking is because there is a set of sc1 for a GS for sale with those offsets and tire sizes. Wondering if i was able to run it on my car without any problems.
Old 07-07-09, 09:16 PM
  #597
maverick10
maverick10's Avatar
Default Linea Corsa Dyna wheel fitment
Hi, I have been debating on wheels but now I think I am ready. I like the Linea corsa Dynas and the hyperblack with polished lip I am told fits the IS350 BBK. But the front is 19 x 8.5. +28 offset. Will I have major rubbing issues with that offset with 235/35 tires?
Old 07-07-09, 09:22 PM
  #598
GiantsFan
GiantsFan's Avatar
I thought you need to run spacers to clear the front bbk ... ?
Old 07-07-09, 09:24 PM
  #599
maverick10
maverick10's Avatar
Not on the hyperblack with polished lip. At least that's what I was told.
Old 07-07-09, 09:29 PM
  #600
A1Lexis
A1Lexis's Avatar
Contact Zoeb with wheeldude and he will give you the correct answer.
Quick Reply: Will those wheels fit? START HERE.
