Will those wheels fit? START HERE.
#602
What are you lowered on? I've been going back and forth on these wheels as well. I believe that Wheeldude recommends 235/35/19 for the front & either 265/30/19 or 275/30/19 for the rear.
#607
#609
Former Sponsor
The Hyper Black w/ Polished lip and Gold w/ Polished lip are a newer batch that have a +28mm offset in the front.
With the new batch that has the 28mm offset, you will be able to run them on the IS350 without having to run spacers
The only color that needs spacers right now is the full hyper black
The new machined finish with clear coat (polished) will be available with a +28mm offset
Those will be in stock end of this month.
Zoeb
#612
Yes, I know the color doesn't matter but currently that is one of the color choices that supports the IS350 BBK without the spacers and I did ask Wheeldude and he was not 100% sure on the rubbing. So that is why I posted here to ask any other folks with similar offsets.
#613
Actually as of right now it does.
Zoeb
Zoeb
