Will those wheels fit? START HERE.
#901
What johnnyboy said, 215/35. I previously ran a 225/35 and switched to a 215 because my 225 was rubbing. I have a 19x9+29 offset too. So If I rubbed on that, you'd more than likely rub with a 225 on a +18.
215 ain't so bad. When it's on the wheel, it's a minimal reduction in wheel lip protection as well. The way I thought about it was, even with a 225 my lip would get damaged. Just try to be a little more of a cautious driver. Good luck!
So the answer seems like, even if I bend the tabs and heat gun/push the liner, I'd still rub too much with 225.
Thanks everyone,
Noz
#906
#910
mannnnnnnnnnnnnnn u dont need to make like 10 threads lol jus make ONE and keep updating it if u have more questions...
and those should fit
edit: i dont mean to be a douche, but this happens allot , so many useless threads lol
#913
Offsets again..Help Pls..
Hi guys,planning to get these wheels and they are used and on the net,so its not possible to try them on before purchase.
Its 19x8.5 with 39 offsets and 19x9.5 with 45 offsets work vs xx.
Plan to lower on eibachs.
Will the front be ok?
I know the rears are weak with +45 but may i know roughly how much will it come out compared to the oem 17x8?
And one more thing,some are high disk type for BBK and some rims are normal type,will the appearance or offsets of the rims differ from each other like lip size?
Thanks and cheers!!
Thanks and cheers!!
#915
Thanks for the reply iSuxel.
Just found a wheel offset calculater site.
base on the site from 8" width with 45 offset (OEM) to 8.5 width with 39 offsets the wheel will extend 12mm.
And with the rears 8x45 offset to 9.5x45 offsets,wheels will extend 19mm.
Is this correct?
Are the calculation spot on?
http://www.1010tires.com/WheelOffsetCalculator.asp
Thanks
Is this correct?
Thanks
