Will those wheels fit? START HERE.
#932
Wheel Sizes
I asked for suggestions on wheels sizes not too long ago and I think I am going to go with 19x9's all the way around to keep tire costs down. Can a get a suggeation on what offsets I should get, here are my options:
19x9 +20
19x9 +37
19x9 +42
Also, I am planning on getting 225/35's, does that sound right?
Thanks.
19x9 +20
19x9 +37
19x9 +42
Thanks.
#934
you plan on dropping the car? what look are you going for? you want a conservative set up? aggressive? personally i would go with 19x9 +20 but thats my own taste.
if you want something mild, you can go with the 19x9 +37 and run 235/35 tires
#937
I have the FSport Springs so a little bit of a drop. I do want it to be fairly aggressive but I don't want to do any modding to the fenders.
#939
hello. im planning to get the vossen 083 19" 8.5/10. my car is currently dropped on f-sport springs. i need help with offsets, dont know much about them. i want a look thats in between stock and flush look. tire size recommendation? also, will there be any rubbing. suggestions are greatly appreciated. thanks!
#941
Sorry i'm a noob to wheel.
I'm looking to get these rim but they only come in 18x8 and not 18x8.5
5x114.3+40 mm offset
You think it would be okay all Four 18x8 rim, and run bigger tire on the rear to have the staggered look?
Would I run into any problem performance/roughness wise?
#942
Just gonna add to this thread rather than start a new one:
So I've been looking at Volk SF Winnings in 19x8.5 and 19x9.5 with a 38 and 42 offset respectively, but I found a set meant for a G35 coupe, and was wondering if this set-up would work my 350. The stats are as follows:
WIDTH: 10.5 Rear, 9.5 Front
OFFSET: +19 Rear, +17 Front
LIP SIZE: 3 5/8 Inches Rear, 2 5/8 Inches Front
Would this work or is it too aggressive. Should I keep looking for a set in the original specs I wanted? Thanks in advance for all your opinions.
