Will those wheels fit? START HERE.
05-19-10, 10:31 PM
^ I can't say for sure since it's such a minor drop there, but you might be able to get away with no rubbing. Normally people with those kinds of offsets (flush) will want to slam their car, which requires fender mods (shaving or rolling), and smaller tires (225/35/19 up front and 265/30/19 in the rear).
05-19-10, 10:43 PM
Quote:
Originally Posted by
whitecel
Can someone let me know if i'm going to have rubbing issues with this setup?
Front: 19x8.5 +22 245/35/19
Rear: 19x9.5 +22 275/35/19
Looking to drop 1" front and 0.8" rear.
front yes, roll them. run a 225/35/19 or 235/35/19
read youll have to shave and run a 255/35/19 and youll be good
05-19-10, 10:47 PM
thanks maybe i'll pass on those. I had a feeling tires and offset were going to be an issue. Wasn't looking to roll or shave
thanks
05-19-10, 10:49 PM
05-20-10, 10:50 AM
anybody running 19x9.5 +22, 19x10.5 +22 ??
05-20-10, 10:53 AM
Those will fit beautifully but you will need fender work.
05-20-10, 11:14 AM
iSuxeL
shave/roll? or pull?
05-20-10, 11:28 AM
05-20-10, 11:50 AM
if i buy 5mm spacers do i need longer studs????
05-20-10, 02:02 PM
suka4thong
Don't roll, just shave with a slight pull.
Damaster32
Yes you do.
05-22-10, 08:09 AM
18x9 +35 offset with 225/40/18 up front?
05-22-10, 09:32 AM
^^Doable, you can go lower on the offset if you want more aggressive
05-22-10, 09:40 AM
Damaster32
I was told for 5MM and under you don't need new studs.
05-22-10, 10:26 AM
05-22-10, 01:17 PM
you can get away with it, but it isnt safe
