Will those wheels fit? START HERE.
Old 06-11-10, 10:31 PM
  #1216
Mv350
Mv350's Avatar
Originally Posted by integlspwr
19x9.5 +22 all around what size tires? ill run mad stretch with no problems.
with how low you are that is not gunna be flush... but you can run general tires 225/35 and spacer the rear 10mm and be perfect.pm cause i know something is up
Old 06-13-10, 01:22 AM
  #1217
AMSPHAN
AMSPHAN's Avatar
Can anyone please let me know if these wheels will fit?
20x8.5 25+ offset front
20x10 40+ offset rear
What kind of tires will I need to run to maintain the same rolling diameter so it doesn't affect my odometer reading? Thanks CL!
Old 06-13-10, 01:28 AM
  #1218
Mv350
Mv350's Avatar
those will fit, 225/30/20 front, and bumper tab mod. rear will fit 245/35/20 rear. and i dont think you will have to shave rear. and your odo change with 20's
Old 06-13-10, 08:43 AM
  #1219
saiyajin
saiyajin's Avatar
Originally Posted by Mv350
8.5+35 all around or 9 +35 all around would work well with 225/40-255/40, depends how low you wanna go. or no drop at all.
alright cool i thought maybe 18x9 at the front may cause some rubbing issues ... plan to lower on BC Coilovers with probably 1 or 2 finger gaps so pretty conservative
will the +35 offset be flush in the 18x8.5 or 18.9 application??
Old 06-13-10, 10:26 AM
  #1220
AMSPHAN
AMSPHAN's Avatar
Thanks! Anyone have the link to the DIY "bumper tab mod"? I recall seeing it some where but can't seem to locate it.
Old 06-13-10, 07:07 PM
  #1221
AMSPHAN
AMSPHAN's Avatar
Sorry, just found out it's actaully 20x10 and 25+ in the rear. Will it fit without folling the fender?
Old 06-14-10, 01:16 AM
  #1222
Mv350
Mv350's Avatar
you will defiently have to shave or roll the rear. i recomend shaving.
it where the fender and bumper meet, youll have to pull your fender liner back to get to it.
9+35 will sit more flush at that drop.
Old 06-17-10, 05:25 AM
  #1223
Rash
hmm
Rash's Avatar
Does vossen concaved 20x10.5 +30 any different than 20x10.5 +30 with lip?
This may be a stupid question but someone told me the concaved won't fit the rear.
Old 06-17-10, 08:54 PM
  #1224
YellowCopy
YellowCopy's Avatar
Default Fitment questions (semi repost)
I posted this in the aftermarket wheel thread, but it does not seem to get alot of traffic these days! Soooo, repost!
Hey guys, I need some help. I have been crunching numbers and looking through this thread (the aftermarket wheel thread) for the past 4 hours. I am a wheel/offset NooB. I am trying to get past that, so if I ask a funny question, flame me if you must, but please give me some answer.
I have a set of 5Zigen wheels on their way to me and was planning on going pretty conservative with the tire sizes. However, I have seen a post for some new tires at used prices and now I'm curious if I can save a couple of hundred bucks, help out a fellow member, and have it work right and save some money with better performance.
Specs on the wheels are Front: 19X8.5 +45/Rear: 19X9.5 +38.
Specs on the tires are Front: 245/35R19/Rear: 275/30R19
I think the front will fit ok. I am concerned about clearance with the spindle due to my higher offset and then clearance on the rear fender due to the low offset.
I have not done any fender mods and I am sitting on s-tech springs.
1) Have I interpretted the information here correctly or am I completely off base?
2) Will it fit?
3) If not, what would need to be done to make it work, and would it be worth it?
Old 06-18-10, 10:42 AM
  #1225
YellowCopy
YellowCopy's Avatar
Anyone, Anyone? Bueller?
One time only bump. If I cant get some info, I will get some more conservative tires and play financial russian roulette :P
Old 06-18-10, 10:56 AM
  #1226
iSuxeL
iSuxeL's Avatar
1. You're completely off base.
2. Yes it will fit with no complications.
3. Your tire sizes are too big IMO, go with a 225 up front and 255 out back. Or even 235/265.
Your specs aren't that aggressive. Especially the fronts.
Old 06-18-10, 11:15 AM
  #1227
llamaboiz
llamaboiz's Avatar
OP question: what made you choose those offsets?
Old 06-20-10, 01:47 PM
  #1228
hidfanatic
hidfanatic's Avatar
Someone is selling me their rims. Do you guys think a 19x10 +36 and a 19x11 +23 will fit? The wheels are work vs-xx in O-disk (deep rim disk). I'm not worried about rolling/pulling the fenders, i'm just curious about whether or not it would clear is250 brake calipers.
Old 06-20-10, 01:59 PM
  #1229
Hoovey689
Hoovey689's Avatar
^^^ Yes they will fit
Old 06-20-10, 02:14 PM
  #1230
rule1223
rule1223's Avatar
concave makes diff on clearing bbk.
Quick Reply: Will those wheels fit? START HERE.
