hid help
hey i'm new to installing hids, got the extreme hid 6500k from xenondepot. The Kit comes with a relay and needs to be connected to a body ground (-). where would be the best place for this? pics would also be helpful! thanks for your time.
right where the shock towers are. there should be silver screws that go into the body. just unscrew those and attach the lead. there should be another wire going to the ground on the driver side. passenger side is under the airbox.
i can try to dig up some pictures of my install later tonight if you still can't find it.
i had the same problem when i was installing the xtreme kit. hard to find where to ground it at first.
lexus27
12-29-05 09:35 AM
