anyone use 18" front 19" rear? with pics?
just curious, anyone try this setting with 18" wheel in the front but 19" wheel on the rear?? reason is i think 18" wheel can provide better handling in the front amd 19" wheel can provide better grip in the rear for IS350. advantage or disadvantage?
i like 18 in the front for more side wall then 19 but 18 in the rear will be too much side wall for 255 tire than 19. try to find a balance for good looking, handling, and comfort as well.
The 18's will probably do better on the rear too, unless you mean having a wider tire on the rear with the 19's? then I guess on how much wider these tires are. All this is assuming you have the same brand/model tires on both rims. Lets see what ppl say
