Check VSC, Check Engine, and Traction Control lights came on among other things.
This just happened to my wife's car today. All warning lights on as described above and initially she said it was shaking badly. When I came home to check her car, I didn't experience any shaking but the lights are still warning. Do I need to take to dealer to reset? Seems like a common unsolvable problem according to my internet research.
BTW, I did an oil change 2 days ago and reset the oil maintenance light and car is IS250 AWD with about 63k mi.
The reminds me of my S2000 which also has a map sensor that is sensitive to weather changes and the symptoms are very similar. Loss of power, shaking and check engine light which goes away the next day.
Hi-
I got 06 is250 AWD.. While driving in the rain, I got Blinking Check Engine, VSC on, and loss of power. Got home, restarted the car and everything is back to normal now.. Will I be able to retrieve any error codes from that incident or it can only be done while Check Engine is on? Is loss of power in my case = misfiring = problem with exhaust valves (Lexus TSB)? Thank you in advance.
Hi-
I had this problem on my IS250 awhile back, I assumed it was misfires. I took it to the dealer they thought that I needed new valve springs so I waited for a week for them to ship it. In the end they said that my car had a lot of carbonation and they decarbonated it, it seems to be a common problem on the 250 engine, on the 350 its cool because of different fuel injection methods.
SeanIS350
09-18-15 08:31 AM
kchow510
01-22-13 04:52 PM
