IS350 Spark Plug Change...Toyota told me 100k miles
http://www.densoiridium.com/faq.php
it actually rates it up to 120k. however im in total agreement with you kurtz, i would never let my plugs go for that long
There is no way im letting my plugs go 100k before I change them. I changed my plugs at 55k miles. I noticed the engine ran a little smoother and plus I got to inspeck and make sure things are going ok in the cylinders.
I did mine 2 weeks ago. The cost for me was $117 + $10 for the wrench extension. The dealer wanted to charge $415.
It took me about 2 hours because I had to drill the head off from one of the hex bolts that holds the large black box that sits under the removable top engine cover.
I will say that the 3 on the passenger side was the easiest (on the IS250). It took about 15 minutes to replace. The 3 on the driver side is a SOB. When I took out the plugs, there were past their time (68k). I have noticed better response, but MPG's are a little off. It could be due to my heavier than usual right foot.
I have 50K on mine. I took it in and asked them to flush and replace the transmission fluid (which is also transfer case fluid on my AWD), flush and replace the coolant, and to replace the spark plugs. They refused to perform ANY of these services. I told them that the car is going to see alot less usage because I bought another car (so I won't be driving the IS much) and that I wanted to have all the fluids and plugs fresh. Still, the technician refused. They said the car needs no service.
They told me 100K for the Transmission fluid and the coolant and 120K for the spark plugs!!
I still think that at a minimum the transmission fluid should be changed.
Any advice?
Any advice?
sorry for resurrecting this thread. but it seems like there is a big debate. I had two different service advisors tell me 60K and 120k for spark plugs. my gas mileage is about 25 on avg. mostly highway miles. I'm at 68K right now.
You already posted a thread about this here: https://www.clublexus.com/forums/is-...k-or-120k.html
Were your questions not answered?
Jeff
Jeff
Jeff
Jeff
I can't figure out why you want to take the occasional isolated ignorance of a dude at a local dealership over what it written down in the manual by the people who actually designed and built the car
