Tire Pressure sensor...
Old 03-30-10, 12:43 PM
Fuzzie
Fuzzie's Avatar
Default Tire Pressure sensor...
I just got my tires changed recently with brand new tires....a couple of days after i got the tires replaced, i got a low tire pressure warning. i pumped more air into the tire. a week after that i got the warning again... now its been 3 weeks since i pumped air, and i just got the warning again! Anyone think i got a hole in my tires? or, is this Bipolar @ss weather messing with my sensors? the warning light seems to come up on a colder day...
Old 03-30-10, 12:48 PM
Edz71
Edz71's Avatar
Tire might be just fine ?? I had it happen once that the seal on the rim was bad and had to re-instal the tire........... good luck
Old 03-30-10, 01:10 PM
2slow
2slow's Avatar
It did that to me once when it was really cold out and sent me a TPMS warning.
Didn't have time to fill it up so i left it. Sun came out it went away.
Where did you get the tires installed? I hope they took off the TPMS before they dismounted your old tire. They may have damaged it.
Old 03-30-10, 02:03 PM
Fuzzie
Fuzzie's Avatar
tire kingdom.... so you just ignored the warning lights and it eventually disappeared?
Old 03-30-10, 04:40 PM
javyLSU
2IS OG
javyLSU's Avatar
Your time would be better spent getting your tires and wheels checked instead of asking people on the internet who have never seen your tires whether something is wrong with them. I'd get them checked - the temperature should not be causing the TPMS to go off if they weren't already low an air to begin with. Good luck!
Javier
Old 03-30-10, 10:42 PM
2slow
2slow's Avatar
Ignored it for like 4 hours.
Old 03-30-10, 10:50 PM
blk250
blk250's Avatar
check all four tires, and get all 4 tires to the same PSI. (remember/note down the PSI number)
then check them again when the sensor display again.
if one of them get different (lower) PSI number than previously noted down then you would know which one is leaking air etc...
98023IS250
98023IS250's Avatar
when it happened to me, I had a nail in my tire...
Old 03-30-10, 11:21 PM
uz07lex
uz07lex's Avatar
You should take a big bucket with soapy water and submerge the tire and rim. This would eliminate if the tire has any leaks. If it doesnt show a leak, the people that changed your tires owe you a sensor.
Old 03-30-10, 11:46 PM
FoUr OuNcE
FoUr OuNcE's Avatar
go to the menu on your onboard computer, the one in between your rpm and speedometer, and make sure the setting is set on main instead of 2nd..regarding wheels
jahdish
12-21-15 06:24 PM
aasim305
06-18-15 10:45 AM
LIMS407
01-24-11 07:07 PM
sf7307
03-24-08 09:48 AM
John007
10-03-07 09:32 AM
Quick Reply: Tire Pressure sensor...
